Old 04-08-2003, 06:19 PM   #15
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
Exclamation they must be different
chantal and mike
my 4700 must be equipped differently than yours.
it has a juntion box at the base of the left hand side of the drivers seat. it has about 8 or 10 LED's (light emmiting diodes) on it. it is for the remote start etc.
the over head console has six switches in it for cargo/spot lamps and the pto.
i thought all internationals were equipped this way.
my thought was that you could tap into any of the key on accessories to power a battery solenoid.
back to square one.
you need to find a circuit that becomes hot with the key to close a relay.
then you could use the bosch relay that frank posted.
john
Old 04-08-2003, 06:57 PM   #16
John,
I am so happy to see that our truck is not equipped like yours......for a second here, I thought that Mike was completely senile
We already used a hot location in the box for the CB, so I guess we will do the same for that.
Thanks a lot to all of you.
femuse is offline   Reply With Quote
Old 04-08-2003, 09:40 PM   #17
Bosch relay wiring
More....
This is a drawing of using 2 relays to share the load. These will last indefinately.
Name:	bosch cube relay a .jpg
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Old 04-09-2003, 04:31 AM   #18
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
perfect!
frank
excellent!
john
Old 04-09-2003, 06:28 AM   #19
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Those Relays.....
We used a lot of those Bosche Cube relays at a two-way radio dealer I used to work for. We used to buy them by the gross for aboout $1.98 each. I felt bad for a guy one Saturday when I was at the parts counter at the local Chevy dealer when they charged a guy $30 for one They are a bulletproof relay, used in thousands of applications. We used them mainly for supplying power to light bars and sirens and activating horns on "recalls". Never seen one go bad.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 04-09-2003, 10:23 AM   #20
Thanks a lot for the drawing.
Mike is very familiar with the Bosche cube relays, used in our Peugeots (known to our local DMV as Piew Goats).
I will show the drawing to Mike as soon as I can figure out how to stand the monitor on it's side
Thanks again.
need help on univolt converter 72 Overlander 1 Electrical - Systems, Generators, Batteries & Solar 90 06-25-2009 11:55 AM
Basic Brake information David Hall Brakes & Brake Controllers 18 03-04-2004 06:23 PM
Battery Box wire?? OakHill Electrical - Systems, Generators, Batteries & Solar 9 12-11-2003 09:50 AM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Dumb question - 345LE - does the gennie charge the auto battery? williamhenshall General Motorhome Topics 6 08-26-2002 05:49 AM
