Old 09-11-2014, 06:51 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
How to replace the solar controller.
I need advice on how to replace the solar controller on our 2012 FB FC as it appears that it has gone bad. It is located next to the front wall under the bed and does not appear to be easy to access. Must I remove the bed in order to do it or is there an easier way?
urnmor is offline   Reply With Quote
Old 09-11-2014, 08:56 PM   #2
richinny's Avatar
2011 34' Classic
is it bad? that controller might still be under the manufacturers warranty. try calling them and they'll walk you through the replacement.
Ricky
Old 09-11-2014, 09:41 PM   #3
1974 Argosy 20
Kooskia , Idaho
If your 25' FB FC is built like the 20' FB FC that I have, there is virtually no way to get to the front, under bed electronics without taking the mattress out, and the plywood off the top to gain access to things. I have had mine apart several times to do the electrical modifications I wanted to do. PITA, but necessary. Removal of the road side "arm" is also needed to get the plywood out. There are screws in the side of the arm, as well as the bottom. Side screws are hard to find.
Old 09-12-2014, 04:43 AM   #4
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
I have the 2012 Serenity FB and replaced mine with minimal effort, same location. You do have to move the mattress, but you only need access through both the lifted bed plywood and the little access piece that AS screws in at the head of the bed. I mounted my new controller more to the left side so I can see the lights on it more easily.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-12-2014, 06:07 AM   #5
urnmor's Avatar
Berlin , Maryland
My thanks to all. It looks like I will have a project this week.
again my thanks for the advice
John
I'm confused, where do I wire in solar controller bmklawt Generators & Solar Power 7 06-19-2011 11:22 PM
Whats the best Solar Charge Controller? Keyair Generators & Solar Power 17 05-09-2011 05:04 PM
Where do I connect the solar charge controller on an '87 Soverign? willbrackman Generators & Solar Power 2 08-01-2010 08:11 PM
Univolt replacement now or later, and does solar affect which charge controller? mlepisto Batteries, Univolts, Converters & Inverters 3 11-05-2009 07:16 PM
New F150 '09 brake controller vs. Prodigy brake controller dukester Brakes & Brake Controllers 17 01-20-2009 10:46 PM
