Old 08-29-2015, 04:10 AM   #1
Leesburg , VA
How to prewire for solar
Hi everyone.
Quick question while I have my inner skins off. I want to prewire for solar.
What wires should I run up to the roof? I have seen some on amazon but I am not sure which ones would be best.
Any help would be appreciated.
cecreighton is offline   Reply With Quote
Old 08-29-2015, 05:36 AM   #2
arktos55343's Avatar
1972 25' Tradewind
Hopkins , Minnesota
Not an expert here, but working on the same issue. The longer your run, the heavier the wire should be due to voltage drop. Most non-custom systems come with or recommend #10 wire. #10 is ok from your panel(s) to your entry point. From the entry point to the controller should be heavier wire (#4 - #8). You can then splice in a short #10 to make the connections to your controller. But the heavier wire on the long run will reduce your voltage drop, which is an absolute must if you are going to get the needed voltage out of your panels to charge your batteries and power your stuff. Even heavier cables should be used between your controller and your batteries (#2) and from your batteries to your inverter.
arktos55343 is offline   Reply With Quote
Old 08-29-2015, 06:32 AM   #3
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
Originally Posted by cecreighton View Post
Hi everyone.
Send a PM to Lewster (Lew Farber,) he is the expert and can advise you on which size wires to run.
Bob Martel
WBCCI# 5766
solar prewire location: 2007 20' Safari SE DBULL Electrical - Systems, Generators, Batteries & Solar 2 10-21-2012 10:01 PM
Solar Prewire - 2005 Safari, 22 ft jsutro Generators & Solar Power 18 04-06-2012 01:29 PM
Solar Battery Charger Prewire t7389sg Classic Motorhomes 0 08-18-2011 08:01 AM
solar/use prewire? billiards Generators & Solar Power 4 07-30-2008 01:54 PM
Solar Prewire, What Does It Mean? dottie dawglips Generators & Solar Power 6 08-06-2003 07:30 PM
