Old 11-16-2012, 02:17 PM   #1
Airstream Dad's Avatar
2005 28' International CCD
Arlington , Virginia
How to Power Running Lights in Camp?
I searched the forums for this, but couldn't find an illustration or how-to guide for how to insert a wire in my 7 way hitch plug so that 12V is supplied to the trailer running lights. It looked as simple as running a wire from one pin to another.
I saw this at a Fall rally and it nicely lit up my AS in the dark.
Does someone perhaps have this handy or can send a link to the right forums thread?
Best
Airstream Dad
Airstream Dad is offline   Reply With Quote
Old 11-16-2012, 02:31 PM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
I don't use a wire I use a fuse, you have to look at the pin diagram, but they are the same width as a modern fuse. 12+ to marker light. I think they are side by side. You can also plug in a flasher. BTW do at you own risk.
Best
Airstream Dad
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-16-2012, 02:37 PM   #3
Alumaholic's Avatar
1966 24' Tradewind
Albuquerque , New Mexico
Images: 33
They are the top, two slots on either side of the molded indexing tab on the connector.
Just use a multi-meter to find the battery. The one next to it is the running lights.
I use an automotive fuse as a jumper.
The blades are the right size and the right distance apart.
Hope this helps.
Ken L
1966 Tradewind 24
2007Chevy Silverado 2500 HD Duramax/Allison
Four Corners Unit WBCCI #8654
Alumaholic is offline   Reply With Quote
Old 11-16-2012, 02:40 PM   #4
Wise Elder
Jammer's Avatar
2010 30' Classic
It can be done by jumpering the two terminals on either side of the indexing "ridge." See the diagram.
It is said to be poor etiquette to do this indiscriminately in a crowded campground.
I have added a switch inside my trailer for doing this because I have found that operating the running lights while parked is, as a practical matter, most useful when someone is trying to find the trailer in the rain.
Old 11-16-2012, 02:44 PM   #5
Jim Clark's Avatar
Looks like Pins 3 and 4
Jim N5TJZ Air# 174
2011 F150 Ecoboost
Old 11-16-2012, 02:44 PM   #6
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
It's Only Poor Manners Because...
...every wife in camp will ask her husband/partner why their Airstream isn't lit up like yours. It's embarrassing for them.
Ken L
1966 Tradewind 24
Old 11-16-2012, 02:50 PM   #7
AIR #8691
2006 25' Safari SS SE
Northern , Virginia
I assume you have the standard 7-pin plug, where pin # 1 is ground and pin # 3 is for the running lights. Look at the end of the plug to see the pin ID numbers. You may want to get or make a diagram for the pin connections. The idea is to connect pin #3 to the pin #1 to complete the circuit. The way I did it was to buy a mating connector (like the type on you tow vehicle) and use #14 gage wire to connect those two pins together within the new connector. Wrap it in tape or seal it in plastic or hot glue. Then I just have to plug my connector into the Airstreamís plug. Itís safer to power the trailer running lights only when you are on shore power. Good luck.
JStanley is offline   Reply With Quote
Old 11-16-2012, 03:04 PM   #8
Wise Elder
Jammer's Avatar
2010 30' Classic
@Jim Clark: That diagram is so wrong I don't know where to start.
@JStanley: Connecting 1 and 3 won't do anything, you have to connect 3 and 4.
Old 11-16-2012, 03:19 PM   #9
Alumaholic's Avatar
1966 24' Tradewind
Images: 33
Quite Right, Jammer...
Jammer has it right.
Ken L
1966 Tradewind 24
Old 11-16-2012, 04:38 PM   #10
Bk Yd Safari's Avatar
2008 20' Safari
Tunnel Hill , Georgia
what amp fuse?
thanks
Remember its not the destination, but rather the journey.... its what's in the middle that matters the most!
Bk Yd Safari is offline   Reply With Quote
Old 11-16-2012, 04:44 PM   #11
Bigventure's Avatar
2016 30' Classic
Hinckley , Ohio
Woodland travel Center sells a rubber cap that will turn on the running lights safely. It fits right over the plug. Just use google to find them.
Bigventure is offline   Reply With Quote
Old 11-16-2012, 05:27 PM   #12
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Camperlite: CamperLite Camper Night Light, Camping Lites, RV Patio Lights, Travel Trailer Camping Lights***** - Home
MICHAEL
Old 11-16-2012, 05:34 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We use a device called a "FlashCube," but the company that made them is no longer around...it allows the tail lights to flash if you want as a safety feature (while unhitched parked along the road during an emergency, for instance)... and also the running lights to be on when unhitched ...
Here's another product now available called the RVGlow...if you don't want to make your own...it has a fuse in it, too... (I have no connection to this vendor.)...
TB & Greg and Abbey Schnauzer
#3954
Old 11-16-2012, 06:39 PM   #14
pgr32e's Avatar
1974 27' Overlander
Sault ste Marie , Ontario
I hard wired mine to a switch mounted on the front shelf behind the gaucho. Run a wire from the running light contact in the umbilical plug inside the front wall to a splice with two wires. One goes to a flasher then to one end contact of a single pole double throw switch. the other goes to the other end contact directly. from the center contact another wire goes to a fuse then to the 12v+ contact of the umbilical plug. Thus the switch is steady, off, flash. It looks kind of neat and if for some reason you have to leave your pride and joy on the side of the road it will be seen, at least for as long as the batteries hold out.....Phil.
pgr32e is offline   Reply With Quote
