11-17-2012, 07:00 AM
#21
2004 30' Classic Slideout
2021 33FB Classic
Colleyville
, TX
Use the flat, red fuse.
In dog years, I'm dead!
11-18-2012, 07:38 PM
#22
2005 28' International CCD
Arlington
, Virginia
Thanks all! I just ordered one of the CamperLite rubber caps, I like the idea of sealing off the connection in case of rain.
Cheers,
Airstream Dad
11-19-2012, 05:39 AM
#23
1995 30' Excella
Bowie
, Maryland
I was able to run a wire from an unused switch near the door (I assume it was intended for the valance lighting option) to a junction in the parking light wiring under the closet. It took about 3 minutes to run the wire and 20 minutes to get the wire cap back on (it's difficult to reach). It works great!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
11-23-2012, 07:26 AM
#24
Biloxi
, Mississippi
Bob, can you post a schematic of your top picture?
MICHAEL
11-23-2012, 02:27 PM
#25
Salem
, Oregon
Hi, sorry, but I don't have one. It started with a few lines drawn on a piece of paper and other changes were done while in the process of making it work with LED tail lights. The white lights were added to give enough resistance to make the lights flash while in the flash mode. I also changed one or two switches in the process too.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
11-23-2012, 05:27 PM
#26
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
B/U lights....
Never wired the tear-drops....
But the B/U light's have come in handy breaking camp and packing the Classic's trunk.
11-23-2012, 07:38 PM
#27
2003 22' International CCD
Kiln
, Mississippi
All of this talk about use in the campground is great but I built mine for use when (not if) I have to leave the camper on the side of the road for repair to the truck if I'm towed. Just remember - it will run the battery down of not connected a campground power source.
The simplest method is to get an automotive fuse holder with two wire leads - you can twist the wire ends and put them into the slots on the umbilical cable on the trailer. I did this for 2 years - I used a 20 amp fuse - that is what protection for that circuit in my truck for the trailer lights. The cost is about $2 at Walmart. You can use it later to build a fancy plug adaptor - just buy the umbilical connector for a car at Walmart and do the wire connection inside the plug housing.
BTW - it's also useful for running lights pre-check before hitting the road when you're alone.
Michael & Tina with Layla and Preston BZ The family has grown. 2003 22' INTERNATIONAL CCD
11-24-2012, 08:09 PM
#28
2005 30' Land Yacht 30 SL
Oakland County
, Michigan
Originally Posted by Jammer
It is said to be poor etiquette to do this indiscriminately in a crowded campground.
I agree with Jammer, too much light in a campground is annoying.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
11-24-2012, 09:47 PM
#29
Salem
, Oregon
Hi, I agree too. My first unit was made for use at Airstream Rallies. My second unit [much simpler] was made for road side emergencies. [ hope I never have to use it]
12-15-2012, 05:03 PM
#30
2006 30' Classic
Yonkers
, New York
CamperLite contact/s
Who has the phone # or correct Web address for CamperLite ?
I placed order (Order Number: 1237) on 12/9/12 and no delivery yet (1 wk). Could it be Holiday rush or what are your product order experiences with camperLite ?. I got the order confirmation but the email address takes no reply. Thanks all.
12-15-2012, 05:45 PM
#31
2006 19' Safari SE
Tucson
There is a Contact Us link in the website...you can email them through that. I don't see a phone number listed anywhere. Good luck...
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
12-15-2012, 07:15 PM
#32
2006 30' Classic
Yonkers
, New York
No luck. Thanks
12-15-2012, 07:32 PM
#33
2011 23' FB Flying Cloud
Perry
I almost pulled the trigger on that ad, but I sent them an e-mail and it was bounced as undeliverable, so I backed off. Keep us posted please.
Roadrunner gave me this link,,, its more expensive but the page does give a phone number. RV Glow - Turn your outside camper lights into patio lights.
"If you don't know where you are going, you will wind up somewhere else." Yogi Berra
12-15-2012, 07:45 PM
#34
2006 30' Classic
Yonkers
, New York
Originally Posted by Snedwid
Will do. Thanks.
12-15-2012, 08:36 PM
#35
2018 25' International
Van Wert
, Ohio
I use a 15amp blade fuse to connect the fins in the seven pin plug...locate the ridge on the plug and connect 11 o'clock to 1 o'clock...it works great.
12-16-2012, 09:13 AM
#36
1995 30' Excella
Bowie
, Maryland
You might want to search around this site for more info - I recall that someone ordered one that looked a lot like that from somewhere on the web, and it just turned out to be an automotive fuse with a cover - they wouldn't even post pictures of it because it was so ridiculously simple and could be built for 20 cents.
12-16-2012, 12:15 PM
#37
2006 19' Safari
New Smyrna Beach
I ordered one and yes, it was just a glorified fuse.............
12-16-2012, 12:50 PM
#38
2006 30' Classic
Yonkers
, New York
Cheers,
Airstream Dad
Airstream Dad,
Any feedback on your order ( delivery time , communication & product quality ?
12-22-2012, 05:57 AM
#39
Arlington
, Virginia
Camperlite Feedback
Sorry for the delay, busy holiday. So to respond to :
Airstream Dad,
I ordered the product online using PayPal. The cap showed up about a week later via standard US post, no issues.
Attached are a couple of photos of the product. It's simple and seems well constructed. I attached it to my AS power plug, and it powered up the running lights as advertised, works well.
Here are several things I personally like about it:
- Note in the photo that the plug includes the rectangular "tab" so that when placing it on the plug, it aligns correctly immediately, no need to figure out which terminals the fuse goes in, making install/attachment quick and easy. Handy at night when dark.
- The plug is made of rubber, so no worries about having fingers near the fuse connectors/wire and a shock
- Similarly, it completely covers the entire plug, so in case of rain, it's contained
Hope this helps,
Airstream Dad
12-22-2012, 06:05 AM
#40
2006 30' Classic
Yonkers
, New York
Airstream Dad,
Hope this helps,
Airstream Dad
Thanks for your feedback , mine finally showed 2 days ago and I completely agreed with all your positive feedback. Thx again
