Old 11-16-2012, 07:36 PM   #15
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Originally Posted by Jammer View Post
@Jim Clark: That diagram is so wrong I don't know where to start.
@JStanley: Connecting 1 and 3 won't do anything, you have to connect 3 and 4.
Want to tell me why? Older style plug?
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-16-2012, 07:38 PM   #16
billymyers56's Avatar
2016 28' Pendleton
Commerce , Texas
I made one of these and the middle is the ground.
billymyers56 is offline   Reply With Quote
Old 11-16-2012, 09:07 PM   #17
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Here is what the manual shows;
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
Old 11-16-2012, 09:16 PM   #18
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
I got a two spade direction signal flasher (about $3.00) at an auto parts store, bent the spades slightly so they plug into the 12v and tail light slots in the plug. Looks pretty cool flashing.Will be handy if for any reason I ever have to disconnect the trailer and go for help at night.
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 11-16-2012, 09:55 PM   #19
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
The flasher connects 3 and 4 in the plug to make the running and tail lights flash.
A wire with a fuse connected between 3 and 4 will keep the running and tail lights on.
Old 11-16-2012, 10:01 PM   #20
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Two home made units.
Hi, I made these two light control units. 10Amp fuses will work with LED tail lights, but I changed to a 20 Amp for those with regular bulbs.
ID:	172875   Click image for larger version
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 11-17-2012, 07:00 AM   #21
ZoominC6's Avatar
2004 30' Classic Slideout
Colleyville , Texas
Use the flat, red fuse.
In dog years, I'm dead!
ZoominC6 is offline   Reply With Quote
Old 11-18-2012, 07:38 PM   #22
Airstream Dad's Avatar
2005 28' International CCD
Arlington , Virginia
Thanks all! I just ordered one of the CamperLite rubber caps, I like the idea of sealing off the connection in case of rain.
Cheers,
Airstream Dad
Airstream Dad is offline   Reply With Quote
Old 11-19-2012, 05:39 AM   #23
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I was able to run a wire from an unused switch near the door (I assume it was intended for the valance lighting option) to a junction in the parking light wiring under the closet. It took about 3 minutes to run the wire and 20 minutes to get the wire cap back on (it's difficult to reach). It works great!
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 11-23-2012, 07:26 AM   #24
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Bob, can you post a schematic of your top picture?
MICHAEL
Old 11-23-2012, 02:27 PM   #25
Salem , Oregon
Images: 18
Hi, sorry, but I don't have one. It started with a few lines drawn on a piece of paper and other changes were done while in the process of making it work with LED tail lights. The white lights were added to give enough resistance to make the lights flash while in the flash mode. I also changed one or two switches in the process too.
2005 Safari 25-B
Old 11-23-2012, 05:27 PM   #26
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up B/U lights....
Never wired the tear-drops....
But the B/U light's have come in handy breaking camp and packing the Classic's trunk.
Old 11-23-2012, 07:38 PM   #27
clancy_boy's Avatar
2003 22' International CCD
Kiln , Mississippi
Images: 8
All of this talk about use in the campground is great but I built mine for use when (not if) I have to leave the camper on the side of the road for repair to the truck if I'm towed. Just remember - it will run the battery down of not connected a campground power source.
The simplest method is to get an automotive fuse holder with two wire leads - you can twist the wire ends and put them into the slots on the umbilical cable on the trailer. I did this for 2 years - I used a 20 amp fuse - that is what protection for that circuit in my truck for the trailer lights. The cost is about $2 at Walmart. You can use it later to build a fancy plug adaptor - just buy the umbilical connector for a car at Walmart and do the wire connection inside the plug housing.
BTW - it's also useful for running lights pre-check before hitting the road when you're alone.
Michael & Tina with Layla and Preston BZ
The family has grown.
2003 22' INTERNATIONAL CCD
Old 11-24-2012, 08:09 PM   #28
Michigander's Avatar
2005 30' Land Yacht 30 SL
Oakland County , Michigan
It is said to be poor etiquette to do this indiscriminately in a crowded campground.
I agree with Jammer, too much light in a campground is annoying.
Bob & Nancy
2005 ASLYG 30 SO
2009 Wrangler Toad
Michigan
Michigander is offline   Reply With Quote
