Old 12-24-2011, 07:07 PM   #29
Images: 59
I believe that's the correct outlet, except that it's really a 120/240 50a outlet.
The Midwest part number from the CW spec is a 120/240 split phase box. Camping World has it listed incorrectly as a 110V box.
Old 12-25-2011, 05:09 AM   #30
CASA3805
casa3805's Avatar
1984 27' Sovereign
Corpus Christi , Texas
Images: 30
Converter
Originally Posted by CeloNC View Post
Thanks again to all for the great assistance. I have a good idea of what i need to do now and I haven't burned the house or the trailer down so i am ahead of the game. All I want for Christmas is a new converter and a 30amp circuit, two things i wouldn't have cared a wit about a month ago. Think I got the Airstream bug. Happy Holidays to all! Bill
Well....this will help you get started on that next project as soon as you have power at your house.
Intelli-Power PD9260C 60A Electronic RV Converter/Charger
It is fun to watch others walk a similar path!
Chuck & Skye
Rock and Roll Will Never Die!
WBCCI 3805
AIR 54011 Since July 2011
casa3805 is offline   Reply With Quote
Old 12-25-2011, 07:35 AM   #31
mefly2's Avatar
2012 20' Flying Cloud
Msla , Big Sky Country
Originally Posted by Aage View Post
Bill,
If you decide to go witih option #1, suggest you put red tape with a note on the switch to the air conditioning or heat pump.
Since you are talking about at home, you might think that you will be the only one to flick switches in your trailer, but your wife|children|close neighbour|whoever might not know that you think that.
Excellent suggestioin ... Not laughing here, but my wife hit the AC/Heat pump while plugged in at home and melted down the adapter. I am not sure just why the GFCI or breaker did not blow, but a little corrosion on the plug or adapter/ cable caused the two connectors to heat up and burn through! Heed the advice given above about max amps and extension cords.
Old 02-02-2012, 11:32 PM   #32
Hodum's Avatar
1995 34' Excella
Corinth , Mississippi
Originally Posted by clancy_boy View Post
Midwest Electric - 110V Electrical Power Outlet Box, 50 Amp - Electrical Adapters - Camping World
Buy the 50 amp 120v box and a 50amp breaker to fit your home electrical box (look in the panel box door for model or brand) and I would use #8 wire. Consult with an electrician for proper wire size. Camping World has them in store, Home Depot or an electrical supply store can order one. Setup is the same as the 30amp.
The #8 wire is rated at 40 amps therefore a #6 which is rated at 60 amps is the correct size for the 50 amp service.
Why settle for anything less?
1995 34ft Classic Excella 1000
2011 F-250 FX-4, 6.7 diesel, 6 speed auto trans.
TAC # MS-8
Hodum is offline   Reply With Quote
Original trailer plug wiring diagram? edglenn Electrical - Systems, Generators, Batteries & Solar 11 11-06-2011 07:51 AM
Wet weekend in our Safari OR How I discovered the Blow Out Plug! Brow324 Plumbing - Systems & Fixtures 16 04-18-2011 11:15 AM
New 30 amp plug needed ck21084 Batteries, Univolts, Converters & Inverters 19 04-08-2011 08:25 AM
30 Amp to 15 Amp Adapter to House Power Question Steamboatbob Batteries, Univolts, Converters & Inverters 20 03-16-2011 09:33 AM
Radio on house battery michalakes Electrical - Systems, Generators, Batteries & Solar 1 01-05-2011 02:07 AM
