Old 12-27-2002, 02:15 PM   #1
Very american 4 a french
brunoffrance's Avatar
1971 27' Overlander
DUNKERQUE / FRANCE , Nord
Images: 68
Question How to convert 220 AC/50hz to 120 AC /60hz
hi there;
i want to plug my A/S in European campgroungs without changing equipments inside who run with 120v / 60 hz. the problem is that we can only plug on 220v / 50hz....
is someone gotten the solution to use genuine A/S equipments ( refrigerator, air cond, converter 120 / 12 v) in europe; Does it exist a special converter 220/50 in 120/60 ?
Or is my international equiped for that , and i don't know ?
if not, why international name compared to the continetal A/S ?
May be European owners can give me the way the do ;
thank you by advance,
Bruno;
brunoffrance is offline   Reply With Quote
Old 12-27-2002, 02:36 PM   #2
Hi Bruno,
i have bought a 1979 Safari from a german dealer in Duisburg, who imported the trailer I wanted from the USA and changed axles, brakes, hitch, and inserted a transformator, which transforms the 220 V to 110 V (for the lights, refrigerator and air condition), and it works fine. Additionally I also can use 220V for whatever I plan.
Cheers, Hans
Hans is offline   Reply With Quote
Old 12-27-2002, 06:55 PM   #3
New Borockton , Alabama
Images: 21
Bruno
I lived if Germany for three years from 94 to 97 and had to use transformers to convert everything we owned in our home. Transformer converts 220 to 110/120 but the hertz rate was still 50 instead of 60. The problem is that the 50 herts caused clocks to run slow and our appliances seemed to fail sooner than normal. Try to find a transformer that converts volts AND hertz.
Randy
Old 12-27-2002, 07:15 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
would this help?
http://www.powersource.net/fc.htm
otherwise i think you would need a motor/generator set.
john
Old 12-28-2002, 12:28 AM   #5
NewStreamer's Avatar
Bruno,
I'm gonna buy the big one in Germany, go to the shop/electronics section power converters
Ron
NewStreamer is offline   Reply With Quote
Old 12-28-2002, 05:47 AM   #6
1971 27' Overlander
Images: 68
thank you , as usual, you're great !
thank you to reply so quickly;
I've sent emails in each site .
Do you have kept your original equipment from US, or you have remove and buy european ones ?
I want to keep the genuine Dometic fridge and AC so, if Idon't arrive to get a frequency converter, I'll try to use them with 50 hz.
The transformer 220v in 120 v is not a problem to find; In France, we used this voltage in the past, up to 1960 I think.
Always a great pleasure to find solutions in this forum.
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 9 02-05-2019 06:38 PM
AC Gasket replacement Sneakinup Furnaces, Heaters, Fireplaces & Air Conditioning 3 11-30-2003 09:07 AM
Fridge doesn't work on ac jwaldin Refrigerators 5 04-10-2003 10:38 AM
Coleman AC Heater Element Pick Furnaces, Heaters, Fireplaces & Air Conditioning 4 12-02-2002 02:04 PM
Yukon AC cuts out towing.... dscluchfc On The Road... 10 07-27-2002 11:01 AM
