Old 05-04-2016, 01:29 PM   #1
FCStreamer's Avatar
2014 30' Flying Cloud
How to connect surge protector?
So I purchased a Progressive Industries EMS
http://www.progressiveindustries.net/#!ems-pt50c/c1ma0
And I am assuming this connects into the campground power, and I connect my TT cable into this.
Question - if camping on a 30 amp campground, and using a 50 amp to 30 amp converter,
http://www.amazon.com/Progressive-In...ilpage_o00_s00
Do I use this converter on the Progressive unit and connect it to the campground power? Will that work?
2014 Airstream Flying Cloud 30 Recliner - WBCCI #4850 - AIR #110821
2018 Nissan Armada SL Tow Vehicle, Equal-i-zer Hitch
Visit Our Flying Cloud blog for my latest adventure!
FCStreamer is offline   Reply With Quote
Old 05-04-2016, 08:56 PM   #2
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
You plug the trailer into the protector and the protector to the shore power. Adapters will have no negative effect on your system.
The surge protector clips to tops off high voltage spikes that could exceed the "break down" voltage of your semiconductor devices. If we still used tubes we wouldn't need one.
sgschwend is offline   Reply With Quote
Old 05-05-2016, 09:23 AM   #3
J2Becker's Avatar
2015 27' Flying Cloud
Santa Fe , New Mexico
Also, before you connect turn the power off at the breaker. Then turn it on after you have it all hooked up. I have heard that prevents some arcing as you insert plugs.
"It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it would just be 'the way'." ~ Rubin, "Road Trip"
__________________________________________________ ___________________________________________
"The most savage controversies are those about matters as to which there is no good evidence either way." Bertrand Russell
J2Becker is offline   Reply With Quote
Old 05-05-2016, 09:51 AM   #4
Rich W's Avatar
I'm In , Kentucky
I power off, put the surge protector on by itself, power on, check the lights to make sure I've got ground and no reversed wiring, then I power off, hook up the AS AC umbilical to the surge protector, and plug the surge protector into the hitching post, then power on. If I'm going to the 50 amp I add my dog bone adapter between the post and the surge protector.
When I leave I power off the post first, then disconnect everything else.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 05-05-2016, 10:18 AM   #5
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
May be overkill, but I do the same thing, only before I use the expensive surge protector I use one of these.
http://www.amazon.com/Power-Gear-505.../dp/B002LZTKIA
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 05-05-2016, 06:15 PM   #6
2016 30' Classic
Santa Rosa , California
I have the same PT50C. When connecting to a 30amp campground outlet, plug the male (30 end) of a 30-to-50 converion plug into the campground outlet, and the PT50C male plug into the female (50 end) of the conversion plug. Then your 50 amp male TT cable end should be connected to the female port of the PT50C. While in use with a 30 amp campground outlet, the PT50C will only display data for one of the two circuits it can monitor - e.g., the second circuit will always show a "0" amp draw.
Incidentally, you can piggyback a 15-to-30 connector on to the 30-to-50 connector to plug into a standard outside home (15a/120v) outlet. When I did this, my PT50C discovered an open ground on my outdoor outlet and shut down the connection to my TT until I fixed the problem.
phann is offline   Reply With Quote
Old 05-05-2016, 07:07 PM   #7
2016 30' Classic
Ps. Here's the converter I use for a 30amp campground outlet:
http://www.amazon.com/Camco-55185-Po...amp+rv+adapter
This is the additional one I use at home with a 15amp/120v outlet:
http://www.amazon.com/Camco-55165-Po...amp+rv+adapter
I'm sure other connector makes/models would also work, but these Camco versions work for sure. Also, my dealer did provide the 30-to-50 connector when my AS was delivered. Maybe your dealer will provide one (or both) as well.
Old 05-06-2016, 10:14 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Easy:
1) Make sure the power at the pedestal is turned off.
2) Plug the surge protector into the receptacle.
3) Plug the trailer umbilical into the surge protector
4) Turn power on at the pedestal.
I leave the surge protector attached to the trailer's power cord all the time and store the 2 attached to each other.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
I'm new. Need for surge protector? bcombs Member Introductions 14 11-09-2013 07:47 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
surge protector pip8688 Batteries, Univolts, Converters & Inverters 15 08-09-2010 05:14 AM
