Old 07-23-2013, 01:40 PM   #1
1997 25' Excella
Waterville , Minnesota
How much time?
Must I wait a certain amount of time to turn the fridge on when we get to our site or can I run it right away?
Bait guy is offline   Reply With Quote
Old 07-23-2013, 01:46 PM   #2
gwg
gwg's Avatar
2015 30' Classic
Glen Mills , Pennsylvania
You should turn it on the day prior, takes a while to cool down.
Run it on LP while towing.
gwg is offline   Reply With Quote
Old 07-23-2013, 01:49 PM   #3
1997 25' Excella
I understand, in some states you cant run LP while driving, that is why I asked if it had to "sit" a hour or two before turning it on. (like a fridge at home)
Old 07-23-2013, 02:05 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Passing Gas (Propane you louts!)
Ammonia refrigerators are very different critters from freon based ones. If you arrive at a full hookup spot and want to turn your refrigerator on using electric, you can do so immediately - and ditto for running it on propane if you're camped and boondocking.
BE AWARE - If your unit is at room temp. and you plug it in OR fire off the burner your freezer will start to get cold first, but it will probably be a whole day before the refrigerator gets cold. Your food doesn't have to spoil while you are waiting for the ammonia to slowly lower the temperature - you can chuck a block of ice, or a bag of ice cubes or even some dry ice into the refrigerator and use it as an old fashioned ICE BOX while the cooling process starts.
Ammonia refrigerators have been around since the 1870's or 1880's. The industrial sized refrigerator was first used by the beer brewing industry... and took quite a while to become a household appliance except for the very wealthy.
In eastern Virginia almost all of our major tunnels and bridges do inspections on RV's to make sure that propane tanks are OFF while traveling. And while fire is a remote possibility most people who DO use propane for refrigeration while on the road - recommend that you turn the gas OFF while refueling your tow vehicle. A buck spent on a bag-o-ice seems like a reasonable safety procedure, does it not?
Sincerely, Paula
