04-15-2006, 10:50 PM
1972 29' Ambassador
1968 22' Safari
Tyler
How much power should it draw?
Today I removed the old Univolt and wired up my new Intelipower 60 with Charge Wizard. At the moment, I have no way to bring shore power to the AS to test it, so I thought that I could take an 800W inverter, attach it to a separate batttery and plug it into the AS to supply the 120V wiring with a few amps for testing purposes. This didn't work--the inverter shut down instantly, as if there were a dead short! Not only that, but after I unplugged the Intelipower unit and tried again it shut down as before. To my knowledge, no 120V appliances are turned on. Everything on 12V still works fine.
Is this just a question of more power needed? Do I have trouble I don't know about? Comments, please!
04-15-2006, 10:57 PM
418
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley
Not sure about the inverter you're using, but my Intellipower makes a pretty good sized spark when plugging in to a 30A 120v outlet, with no load applied, just hooked to batteries. Maybe it has a startup surge greater than what your converter can handle.
04-16-2006, 06:23 AM
Retired.
, At Large
If you can use a small generator, the Intellipower will work on standard household 15 amp service. A Honda E1000 would be more than adequate for this, if you have one.
04-16-2006, 06:58 AM
Vince,
Is it possible the battery that powers the inverter is dropping too low, and the inverter is just shutting off due to low voltage?
BTW, love your user title.
04-16-2006, 07:05 AM
1972 29' Ambassador
1968 22' Safari
Tyler
Originally Posted by markdoane
Vince,
No, because this setup powers an electric drill and other fairly high-wattage devices just fine. The problem is limited to plugging the trailer power plug into the inverter--and note, the shutdown occurs whether or not the Intelipower unit is plugged in to the "patio plug" in the curbside compartment.
04-16-2006, 09:39 AM
2001 34' Limited
The State of
, Ohio
Some things that would otherwise run off an inverter can shut it down on initial connection or power-up. That includes, for example, a TV with a degaussing coil. I don't know for sure, but suspect the Intellipower has a pretty healthy filter capacitor on the 12VDC side that is charging up on power-up, and that would happen whether the batteries are connected or not. That would appear as a dead short to the inverter initially.
Maurice
04-16-2006, 05:27 PM
2005 22' Interstate
Afton
, Virginia
Some inverters do not generate a sine wave, which is what you get from the power company's AC line. The univolt replacement could require a sine wave input for proper operation.
The other explanation has been mentioned, surge current creating a "brownout" dip in voltage from your inverter. Have you used a voltmeter to verify that the inverter is generating 120VAC throughout its cycle from no load to loaded by the unit?
04-16-2006, 09:09 PM
Naples
On that subject, be sure to use an RMS type voltmeter. Anything else will not give you a true reading of the AC voltage.
lewster
