Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 03-19-2014, 11:33 AM   #1
Greer , South Carolina
How does your generator port work?
I've seen on some trailers a shore power port on the front of the trailer for attaching a remote (portable) generator.
How does this work? How is it wired? Are the two inlets wired together, or are they each wired to a transfer switch?
I'm assuming if you are plugging a generator into it, the other shore power plug is not hot if you were to open it's door. Or is it?
wncrasher is offline   Reply With Quote
Old 03-19-2014, 11:46 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
There is a transfer switch, prone to failure based on other threads here. If you plug into the forward outlet, the aft outlet is disconnected. When voltage is sensed again it the aft outlet, it switches back.
Larry
lsbrodsky is offline   Reply With Quote
Old 03-19-2014, 11:47 AM   #3
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
They are wired to a transfer switch. Only one port will operate at a time. If you read through Forum on electrical, you'll find that some folks have experienced problems with this transfer switch. Apparently, it is not the highest quality component and if it fails only one of the two input ports works. I haven't had this happen (yet).
_________________
"SilverLeaf II" 2015 30' Classic
2019 RAM 2500 Limited 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 03-19-2014, 11:59 AM   #4
So are there two transfer switches in your trailer? One for the exterior 30 amp ports, and another for shore power/inverter?
Old 03-19-2014, 01:09 PM   #5
lsbrodsky's Avatar
No, the inverter feeds separate outlets marked as inverter outlets so the inverter is never in the circuit with shore power fed outlets. There is only the one transfer switch for the generator and shore power inlets.
Larry
Old 03-19-2014, 01:25 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
A fact to consider is that this (mis-)feature is present only on trailers with 30a electrical systems. Ordering the 2nd air conditioner, with the attendant 50a shore power, deletes the transfer switch and the 2nd inlet.
It's unclear to me how having a second inlet 20' away from the usual one is of any benefit given that 20' of shore power cord is cheaper, lighter, more reliable, and just as easy to use.
Looking for someone who does airstream restoration work in south florida or florida Laverne76 Repairing/Replacing Floor &/or Frame 3 08-14-2017 09:10 PM
Roof vents mechanism, how work you it ? Gaël Roof Vents, Skylights & Fans 3 04-06-2014 02:17 PM
Is the shower supposed to work or is it just for looks? perryg114 Sinks, Showers & Toilets 4 10-07-2011 07:50 PM
How does this work? DanielB General Interior Topics 6 09-05-2011 05:19 PM
Batteries on 2 amp trickle all winter. Will they work? bonginator Batteries, Univolts, Converters & Inverters 5 04-25-2011 07:37 AM
