Old 11-28-2017, 12:43 PM   #1
Jeffersonville , Kentucky
How do you use "Rally" power ?
I searched the site, but could not find any info.
As I understand, Rally Power is 4 or 5 airstreams sharing one 110 volt 15 amp power connection.
So, how do you hook it to the airstream.
Do you connect it to your power convertor like normal using an adaptor to your nomal 30amp plug. and let the power converter charge the battery. Making sure you do not use anything 110 ? only using 12v
or do you use a separate 110 battery charger and hook the cables to the batteries.
how do you make sure your charger does not use more than 3 amps ?
etc. etc.
Dremel is offline   Reply With Quote
Old 11-28-2017, 12:55 PM   #2
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I'm not aware that any rally organizers "make sure" you don't use more than your allotted power. My experience has been it's the honor system. Everyone in the chain attaches to AC power at the exterior of their RV.
For example, we attended a rally in which two Airstreams were connected to a 15A outlet. In theory each rig is allotted 7.5A. But one could draw 10A and the other 5A and everything would still be okay.
Similarly any AC supply would be divided by how many rigs are attached and each RV would share accordingly. It becomes obvious pretty quickly who is trying to use their coffee maker, hair dryer, microwave, etc. because they are the first to complain the circuit breaker is tripped.
Daisy chaining AC power can be further complicated if the rally organizers are not using appropriate gage electrical cables. The first section of AC cord needs to be able to handle the entire load, then each leg beyond that can be smaller if suited to the downstream requirements.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is online now   Reply With Quote
Old 11-28-2017, 01:07 PM   #3
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
you just take your power cord and attach a 30 to 15amp adapter, and plug it into a "dog bone"; the chain connects from dog-bone to dog bone at each rig.
Then just don't turn on anything high-draw inside the trailer, like the ac or a hairdryer, coffee pot, etc.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 11-28-2017, 01:14 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Different setups at different events. Some are just sharing off of a single outlet while some are fused connections to a system. Keeping the RV batteries charged and low consumption devices such as cell phones are the standard for most situations.
Richard
Old 11-28-2017, 02:06 PM   #5
So your all saying to just plug it in to your normal 30 amp power convertor and let that handle charging of batteries.
Old 11-28-2017, 02:34 PM   #6
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Yes.
Lucius and Danielle
Old 11-28-2017, 03:13 PM   #7
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
A set of kiddy safe plug covers and some painters tape on switches can help you remember what not to use. Electric hot water is an example of one that is easily thrown if you regularly use gas and electric for quick heat up.
We picked up a couple of the battery powered LED lanterns to use for lighting. Worked well. At $9.95 they were difficult to pass up. We also use battery powered fans for ventilation. They are a little pricy, but we use them on 120V shore power too, so they get regular use. Pat
Old 11-30-2017, 08:54 AM   #8
Thank you all for the replies, now I understand
Old 12-25-2017, 12:00 PM   #9
carl2591's Avatar
2005 31' Classic
Garner, , North Carolina
the newer AS with LED lights tend to use less power as well.. I have change out most of the older florescent lights, which tend to draw a bunch of power, with LED strips lights in the existing fixtures.
keeping reefer on gas, no AC, and only use 120v for phone, computer, and camera batteries two trailers can share a 15 amp circuit.. if you use small coffee pot it not a big deal.. but better to turn it off or heat water on gas stove, pour into the grounds in and dip a good couple cups of coffee..
or get one of the old style percolator type coffee pot you fill with water, put the metal basket with tube on and fill with coffee put on gas stove and again good pot of drip coffee.
https://www.walmart.com/ip/Farberwar...lator/10927183
Name:	coffee pot stove.jpeg
Carl, Raleigh NC
2-24-16 got a 2005 Classic 31D
TUG2.net check it out for good rental deals
2003 F-250 SD, CC, 7.3L PowerStroke
WBCCI#1691, Piedmont Airstream Club, Unit #161, Region #3
carl2591 is offline   Reply With Quote
Power outage while on batteries (Flipping use/store switch restored power) TwoSporks Electrical - Systems, Generators, Batteries & Solar 11 12-13-2016 11:06 AM
Do you tow in "use" or "store"? xo1rider 2011 - 2015 International 17 11-06-2011 09:20 AM
Newbie electrical questions -- "Use" and "Store"? jjboone101 Batteries, Univolts, Converters & Inverters 8 08-27-2009 09:44 PM
What do you use to "spackle" interior walls mello mike General Interior Topics 8 11-27-2004 09:24 AM
