Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 11-16-2003, 06:20 PM   #1
davidlaxson
davidlaxson's Avatar
Profile:
How to control inverter noise
Does anyone have any suggestions on how to quiet down the buzz of an inverter ? I installed a new one in my 1972 AS and if the radio or A/C are not on the buzzing can be very annoying.
P.S - the original inverter was wrapped in insulation and covered with an aluminum box. My new inverter suggested not to cover it up, because heat would build up inside.
David
davidlaxson is offline   Reply With Quote
Old 11-16-2003, 09:24 PM   #2
garry
garry's Avatar
Profile:  1969 31' Sovereign
Broken Arrow , Oklahoma
You could use the orignal insulated box and install a small 12VDC fan for cooling. Hole on one side for air to enter and fan as exaust on other side.
Garry
Old 11-17-2003, 06:13 PM   #3
JodynJeep
JodynJeep's Avatar
Profile:
Images: 57
You could try adding a noise filter prior to the invertor - perhaps that would do the trick or try grounding the invertor directly to the frame if possible. The latter is what we used when installing high end car stereos and usually did the trick..
Jody - Jody's Website
JodynJeep is offline   Reply With Quote
Old 11-17-2003, 10:54 PM   #4
Tinsel Loaf
Tinsel Loaf's Avatar
Profile:
Other than replacing the inverter with a new quiet type unit, Garry's suggestion is probably the beast. Build a insulated box and get a 12 volt DC fan with thermostat to keep it cool. However a new quiet unit would probably be your best bet.
Tinsel Loaf is offline   Reply With Quote
Inverters again ! Tinsel Loaf Electrical - Systems, Generators, Batteries & Solar 8 08-22-2004 07:22 AM
1984 motorhome cruise control cooperhawk Airstream Motorhome Forums 2 12-25-2003 08:12 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
Trace Inverter and Electrical Surges NEW2AS Electrical - Systems, Generators, Batteries & Solar 3 04-07-2003 06:22 PM
Inverter problem Don McKelvay Electrical - Systems, Generators, Batteries & Solar 2 11-03-2002 05:40 AM
Cooking Forum - Sailing Forum - Early Retirement - Airstream Trailer - Aquarium Forum - Royal Forum - Book Forum - Yoga Forum - Volkswagen Touareg Forum - Jeep Wrangler Forum - Whitewater Kayaking & Rafting Forum - Fiberglass RV Forum - U2 Forum
