07-23-2009, 07:56 PM
1999 25' Safari
Sebastopol
How Can it Be? 2 Plugs work, 2 Plugs dont
I have a 1999 Safari 25'. All of a sudden, two of the 110v plugs work and 2 don't. The kitchen and bathroom plugs stopped working, the bed and living area plugs continue to work. I'm baffled, please help. Thanks, Ben.
07-23-2009, 08:00 PM
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View
Maybe
I think they are different circuits protected by separate circuit breakers.
07-23-2009, 08:05 PM
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista
Yes try to "reset",all your breakers,push them off, then on. Next you
07-23-2009, 08:06 PM
2006 19' Safari SE
Tucson
Are the kitchen and bath plug-ins GFCI plugs? If so the GFCI might have tripped....
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
07-24-2009, 01:42 AM
Salem
, Oregon
Hi, this is your answer; GFI plugs are located in areas that have water. [kitchen & bathroom]
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
07-24-2009, 07:04 AM
1978 28' Ambassador
Kenton
, Ohio
Last year I replaced all of my breakers, except the GFI (The GFI was $40 so I left it alone). Last week I had this very same problem. My GFI breaker tripped and would not re-set. I had to replace the breaker. I would highly suggest that anybody with an older trailer replace all of their breakers...makes a huge difference. Breakers don't always function or not function. They can also get weak over time and begin to shut off pre-maturely or function erratically. Fairly cheap preventive maintenance. The GFI breakers have 3 wires to them, not just the one that most breakers have. Be careful.
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
07-24-2009, 09:48 AM
1999 25' Safari
Sebastopol
Thanks for the great responses. I believe all of you that its the GIF breakers. Only, the plugs don't have the GFI's in them. Is there a breaker box I can't find in the trailer? The only thing I can find is the 12v fuse box?
07-24-2009, 10:04 AM
1993 34' Excella
Estancia
, New Mexico
There should be a 120 circuit breaker box hidden in a closet or something.
07-24-2009, 10:35 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
The 110 outlets that are controlled by a GFCI breaker in the control box are just standard outlets and would appear just like the others. You need to locate your breaker box and check the breakers. This is almost certainly your problem. If you have an owners manual, it will tell you where the box is. It varies greatly in different model Airstreams. Look for a louvered panel because the breaker box is with the converter and has a cooling fan that needs to vent.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
07-27-2009, 07:09 PM
1999 25' Safari
Sebastopol
Thanks, Brian. I think I found it under the sofa in the back. Very hard to get to. There is a sealed box with two nuts/screws that I have to take off. It is next to the invertor. Does this sound like it?
07-27-2009, 07:44 PM
1978 28' Ambassador
Kenton
, Ohio
It should be readily accessible through a little metal door. It is most likely very near where your shore power cable comes into the trailer. It will look like a miniature breaker box like the one in your house. One of the breakers will be a GFI.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
r+r 120v plugs
LJH |
Lights - Interior & Exterior |
1 |
10-20-2007 09:53 AM |
Cracked Plugs...
canny_banjo_man |
Mechanics Corner - Engines, Transmission & More... |
16 |
04-23-2006 01:10 AM |
Where can I buy 30 amp plugs?
Ultradog |
Electrical - Systems, Generators, Batteries & Solar |
8 |
10-14-2003 05:12 PM |
Window drain plugs
AccessMaster |
Airstream Motorhome Forums |
10 |
06-20-2003 11:37 PM |
Hitch light plugs
ALANSD |
Brakes & Brake Controllers |
4 |
10-12-2002 09:04 PM |
