Old 08-03-2013, 11:17 PM   #1
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
How Amazingly Stupid (on my part)
So I've been working on getting this trailer rehabilitated for almost a year. I've replaced the old Univolt with a new Intellipower, gone through the electrical systems to make sure all the lights and everything worked as they should, etc. Yesterday I took out a small wall heater to accomodate new subfloor and vinyl flooring - the heater was installed in the 90's. When I went to re-install it I got a pretty decent shock! Holy Crap Batman, something is amiss! Nothing else shocked me, just this one thing. So this evening I started investigating. The first thing I did was take my $4.95 circuit tester and plug it in to an outlet and guess what, the lights on the tester indicated a reversed neutral/hot. I doubted the Argosy had been mis-wired since 1972, so I decided to start testing the electricity at the outlet from my garage where the extension chord is plugged in and runs to the trailer. The outlet was ok, so I went to the other end of the extension chord, and it read hot/neutral reversed! The extension chord came with the trailer and is at least 15 years old. I never thought.
I've kept the Argosy plugged in almost full time since we brought it home in September last year, and have used this extension chord the full time. I only run a small oil space heater in the winter, and of course the Intellivolt charges the battery.
Here's the question (sorry for the long post), have I done any damage to any system - like maybe the Intellipower?
Thanks as always
DryFly is offline   Reply With Quote
Old 08-03-2013, 11:42 PM   #2
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I can't really answer your question, but if everything still works, you should be OK. I always have a polarity tester plugged in, in my kitchen. I also, now, have one that I use to check the power pole at the camp grounds. Lucky for you, this could have turned out really bad.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-04-2013, 01:01 AM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
You won't damage anything in the Argosy with the hot and neutral reversed, you just run the risk of a hot-skin problem if you still have the polarity light AND a ground problem. The AC and the Intellipower should be fine.
Remember, polarized plugs are a fairly recent development. You could plug older equipment in either way.
David
