Old 06-25-2019, 01:53 PM   #1
1977 27' Overlander
2008 25' Classic
FINDLAY , OH
Hot Shell Condition
I have what I believe to be a "hot shell" condition on my 27' 1977 Overlander.
While working on the steps today, I was sitting on the ground outside the trailer. I reached into the trailer to grab a tool and when I touched the door frame got a shock. The trailer is plugged into an extension cord and not really using any 120 V appliances.
The multimeter shows 50 VAC between the door frame (and any other point on the outer shell) and earth.
I checked the breaker box and was unable to locate any loose connectors or wires. I checked the shore plug for any loose connections and it was good.
Even with all breakers off, I still get 15 VAC from shell to ground.
I checked the outside outlets and did not really see anything, but the box under the cover is riveted on. No shorts between receptacle connectors and ground.
I tried unplugging the univolt, but it did not make any difference.
I am thinking I may have a neutral wire somewhere with some damaged insulation.
Here is the strange part. I checked the leaking voltage with different breaker box conditions and got different readings.
All breakers off: 15 VAC
Main only on: 15 VAC
Main and "lighting" breaker on: 42.5 VAC
Main and top left: 23 VAC
Main and top right: 16.3 VAC
Main and top two: 24 VAC
All breakers on: 50.5 VAC
Any suggestions?
ShadyBill47 is offline   Reply With Quote
Old 06-25-2019, 03:05 PM   #2
Long Island , New York
Glad you are OK! Some experts will chime in, but in the meantime here are some "hot shell" search results, showing other mentions throughout the AF site -- FYI:
https://www.google.com/search?q=%22h...=airforums.com
Good luck,
Peter
FYI/FWIW
Old 06-25-2019, 05:44 PM   #3
1977 27' Overlander
2008 25' Classic
FINDLAY , OH
Good News/Bad News
Well, thanks for the reply.
I decided to go to Harbor Freight and get a $6 polarity tester.
Turns out several outlets in my garage have an open ground.
Plugged my extension cord into a known good outlet and no voltage issues.
Lesson learned. Never assume your source is good!
Now, off to fix the garage outlets!
Old 06-25-2019, 05:48 PM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
For your info:
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Hot hot hot aluminum! 58cruzer General Repair Forum 23 06-24-2013 01:08 AM
HELP! Can I fix sagging Outriggers with shell on? Or just pull the shell? Mixter Repairing/Replacing Floor &/or Frame 3 01-24-2013 11:59 AM
Shell on? Shell off? Althea68 Repairing/Replacing Floor &/or Frame 55 04-01-2011 09:35 PM
AC just quit working and it's Hot Hot Hot!!! SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-27-2010 09:03 PM
Shell Off vs Shell On Summary mbatm01 Repairing/Replacing Floor &/or Frame 82 01-09-2006 05:46 PM
