Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 08-17-2009, 07:44 PM   #1
Profile:  2008 25' Safari FB SE
Fort Worth , Texas
Angry Hot Ground/Neutral Reversed
I had some power out problems at my RV storage place. When I checked their plug with an ideal #61-500 line tester it was correct with the proper ground. But checking the plugs on the my 2008 Safari I found the ground was Hot, with Neutral reversed on every plug. This is potentially dangerous!
Has anyone run into this and what is the quick fix? Thanks!
Snaken49 is offline   Reply With Quote
Old 08-17-2009, 08:01 PM   #2
Minno's Avatar
Profile:  1972 31' Sovereign
Lexington , Minnesota
Are you using an extension cord? It might be wired incorrectly.
Minno is online now   Reply With Quote
Old 08-17-2009, 08:10 PM   #3
Profile:  1985 31' Excella
battle ground, , Washington
electrical miswiring
man, I wouldn't think that would happen on a new(er) unit. But...first, check the ckt brkr box-white goes to the neutral bar, black goes into each brkr-and the bare (or green) grounding conductor goes to the eqpt grounding lug. If that is okay, then you need to correct the wiring at each outlet. And double check the appliances, too. facing an outlet, the grounding conductor goes to the bottom of the outlet; the neutral goes to the left side (the one with the longer slot) and the hot goes to the right. Most outlets (NEMA) have a gold colored screw for the hot, a silver one for the neutral, and a green one for the grounding conductor. Of course, be sure there is no energy within the entire electrical system before sticking your fingers anywhere. That includes, shore line, generator, inverter, solar.
wmarsha is online now   Reply With Quote
Old 08-17-2009, 10:58 PM   #4
Fort Worth , Texas
I am using the Airstream power supply cable. So there is no chance of a misswired extension cord. I suspect the the wiring is backward at the main terminal feed. Thanks for the suggestions. Will keep you posted on the results.
Old 08-18-2009, 04:37 AM   #5
Fort Worth , Texas
I had some power out problems at my RV storage place. When I checked their outlet with an ideal #61-500 line tester it was correct with the proper ground. But checking the plugs on the my 2008 Safari I found the ground was Hot, with Neutral reversed on every plug. This is potentially dangerous! I am using the Airstream power cord to connect to the shore power so there is no chance of an improperly wired extension cord.
I suspect the line feed from the shore power is wired the wrong way in the Airstream main feed.
Old 08-18-2009, 04:56 AM   #6
Wayne&Sam's Avatar
Profile:  2007 20' Safari SE
Cuddebackville , NY
Images: 16
Did you check the same outlet you plugged into at the storage place? If so, then check the power cord. I read here that recently someone found an improperly wired cord.
Wayne&Sam is online now   Reply With Quote
Old 08-18-2009, 05:19 AM   #7
Fort Worth , Texas
Outlet at storage place is good. Power cord is the AIrstream shore cable. So it should be good!
Old 08-18-2009, 06:54 AM   #8
loudruff's Avatar
Profile:  1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
shore cable
Since all of the plugs in the trailer are wrong, I would suspect that the power cord connections inside the breaker box in the trailer may be wired wrong. At least that is where I would check next.
CP: W/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
AIR#2695
loudruff is offline   Reply With Quote
Old 08-18-2009, 07:38 AM   #9
JPAIRSTREAM's Avatar
, Ohio
Images: 47
How long have you owned this trailer? Is this the first time you checked for this issue?
Just to eliminate the power cord. If you have a friend with another trailer try using there cord. If it goes away then there is the issue.
If this does not work then looking at the marineco hook up might be next. Maybe there is bleed thru on the cabel as well.
JP
JPAIRSTREAM is offline   Reply With Quote
Old 08-18-2009, 08:42 AM   #10
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
NEVER, NEVER, assume anything is correct if there is a problem within a system. Assumptions kill people, especially in my line of work.
Old 08-18-2009, 08:22 PM   #11
Fort Worth , Texas
Well, folks, as the rivet turns the Airstream supplied cord is wired wrong!!!! But they are shipping a new under warranty replacement! :-)
I took my Safari into North Dallas RV to upgrade my AC/Heat pump to a 15,000 BTU which Randy agreed to do on short notice. While he worked the AC swap his electrician checked out the system. Sure enough when they plugged the shop cord in the outlets tested correctly. The culprit was the Airstream supplied shore power cable. So a new one is on the way thanks to the factory. Case closed.
BTW, I bought the unit new from an Airstream dealer in 2008. I would have never checked the outlets had not the shore power failed. Folks may want to add this to their new/old rig checklist!
Old 08-18-2009, 11:07 PM   #12
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, glad you found and fixed the problem. My trailer came with a little yellow polarity tester and it is the first thing we look at when we plug in our trailer at a campground.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 08-21-2009, 10:54 PM   #13
Fort Worth , Texas
Well folks AS came through today with a brand new shore power cord as a warranty replacement. Now that is terrific service response from the AS factory!
Thanks again for all the good advice! Happy camping!
Old 08-22-2009, 12:31 AM   #14
richinny's Avatar
Profile:  1994 34' Limited
Westchester Cty. NY , & Miami FL
i'm glas you didn't end up like this guy!
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
richinny is online now   Reply With Quote
Open neutral diagnosis? markdoane Lights - Interior & Exterior 3 08-07-2009 08:33 PM
Ground wire getting hot????? 86Scotty Batteries, Univolts, Converters & Inverters 23 03-15-2009 03:44 PM
Reversed Polarity? SilverRanger Electrical - Systems, Generators, Batteries & Solar 7 07-16-2007 08:53 AM
reversed polarity? jimnsu Electrical - Systems, Generators, Batteries & Solar 1 10-07-2006 11:14 PM
Reversed Axles on an Airstream HHP Axles 3 08-14-2006 06:17 PM
