Old 08-11-2013, 09:25 PM   #1
time2play's Avatar
2013 30' Classic
Kent , Washington
Hooking up Honda 2000i generators
We have two Honda generators 2000i. We have a few questions about hooking up the generators to our 30' classic.
What kind of cord do you use to hook your generators? Specially, is there a specific brand or type which is better than another? What should we be looking for when we buy a cord? And does length matter? If it's too long, does it affect the power?
Thanks for your help, we appreciate the information.
Yolanda (and Phil)
2013 30' Classic Limited
2015 GMC Sierra Denali 2500HD
ProPride 3P Trailer Sway Control Hitch
WBCCI #7878
time2play is online now   Reply With Quote
Old 08-11-2013, 10:00 PM   #2
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Do you mean to hook the gens to the trailer? If so just use your normal shore power cord, with a 15 to 30 amp dog bone to connect to the gen. If you have a regular 2000 and a 2000 companion you'll need a locking 30 amp to rv 30 adaptor as well as the parallel cables between the gens.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-11-2013, 10:22 PM   #3
time2play's Avatar
2013 30' Classic
Kent , Washington
Dave,
Thanks for your reply. Yes, that's what I mean. We have two shore power cords, and I believe one is smaller than the other. I guess I'm wondering if a shorter cord is better than a longer one, my logic is telling me there would be less resistance in a shorter cord, so less fuel is used. But I could be totally off the wall here.
thanks again for your help on this.
Yolanda (and Phil)
WBCCI #7878
Old 08-11-2013, 10:32 PM   #4
1974 Argosy 20
Kooskia , Idaho
If both are 30 amp cords with #10 wire in them, and are both under 40 feet long, there will be no appreciable difference in them as to voltage, voltage drop, or resistance. No fuel difference will be seen.
Now, if one is a lighter wire, like #12 or #14, you should always use the heavier #10 cable you have, not the lighter one when using appliances like the AC and microwave.
