Old 03-05-2014, 06:31 AM   #1
Ron and Nancy
roloha's Avatar
1997 25' Safari
Villa Hills , Kentucky
hook up tire minder transmitting booster
located in front of my 25 safari 1997 airsztream is electric panel. there are two extra service breakers for 12 volt.
How do i connect the booster wires into the service panel. Don't understand 12 volt dc electric.
Where does the ground wire connect????
roloha is offline   Reply With Quote
Old 03-06-2014, 08:43 PM   #2
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I put the Tire Minder booster in the wardrobe just beside the 12-volt wardrobe interior light, it is actually just on top of the wheel well, and it is attached to the live 12-volt feed to the light. Since I boondock quite a bit and I was concerned about having another "phantom" draw on the batteries, I added a small SPST switch, mounted into the base of the wardrobe light so that the booster can be disabled when not in use. The ground wire from the booster is connected to the negative lead to the light switch.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
blkmagikca is offline   Reply With Quote
235/75R15XL vs 225/75-15 trailer tire perryg114 Tires 129 07-18-2012 01:59 PM
Tire blowout times two Silverscream Tires 8 11-20-2011 09:58 PM
Very strange tire wear rbhinzman Tires 17 10-21-2011 08:43 AM
Need spare tire rim for size 700-15 1976 has alum mag wheels Caravanner76 Wheels, Hubs & Bearings 3 10-18-2011 09:21 PM
Wheel and tire Combo Mr & Mrs S Wheels, Hubs & Bearings 2 05-09-2011 10:10 PM
