Old 03-03-2016, 11:58 AM   #1
Honda generator synthetic oil
I have eu2000i Honda generator & Companion. Is synthetic oil advisable to use instead of the Honda labeled oil 10W30? Knowing Honda wants the entire maintenance program by using their labeled oil, I feel the equivalent spec synthetic oil would be superior. I am not looking to operate the gens at longer intervals between oil changes. I change oil at approximately 50 hours. Any opinions or recommendations regarding using synthetic would be appreciated. Thank you.
Tom Lafferty is offline   Reply With Quote
Old 03-03-2016, 12:07 PM   #2
dznf0g's Avatar
Oswego , Illinois
I use Mobil 1, 10W30 full synthetic
-Rich-
Old 03-03-2016, 12:22 PM   #3
2013 25' FB Flying Cloud
Tallahassee , Florida
I've used the same stuff for the last 20 years, never an issue
Omega Man is offline   Reply With Quote
Old 03-03-2016, 04:28 PM   #4
1981 31' Excella II
New Market , Alabama
I second M1 10W30. Been running it in my truck with 270,000 miles on it. I had to take the engine apart due to non-oil related problems. It looked like new inside.
Perry
Old 03-03-2016, 04:30 PM   #5
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
I use Mobil 1 10W30 in both of our Hondas.
Old 03-03-2016, 05:17 PM   #6
Kittyfeet's Avatar
2016 23' Flying Cloud
Dallas , Texas
I have a Honda 200i-I use Castrol
Kittyfeet-
I hope this day to have the opportunity to help someone in need.
Kittyfeet is offline   Reply With Quote
Old 03-03-2016, 05:34 PM   #7
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
The important thing is, don't mix natural and synthetic. If it gets low, add whatever's already in there. Other than that, either one works.
Cats and ultraleather Airstream upholstery don't mix!
Old 03-03-2016, 06:35 PM   #8
Well Preserved
1993 21' Sovereign
That's what synthetic blends are. I think the figure for benefit is 20-25% synthetic oil. With that said, I wouldn't recommend mixing oils, either, but for the reason that different oil brands contain different additives. Some of the additives don't play as nice with others as they should.
For the small amount of oil we're talking about, straight synthetic would still be best.
I remember the first oil change interval being 50 hours, but from then on, it is more like 200 hours.
Old 03-03-2016, 06:45 PM   #9
dznf0g's Avatar
Oswego , Illinois
I never reach the hour bogey. I just change it once a year.
-Rich-
Old 03-03-2016, 08:19 PM   #10
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
I use Mobile 1 in both of mine
Old 03-03-2016, 08:21 PM   #11
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use synthetic in all our small engines. I think it's better in the long run and cost is insignificant in the big picture.
Doug and Cheryl
Old 03-04-2016, 07:58 AM   #12
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I use Mobil 1 in all my gas engines that are not gas-oil mix.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 03-04-2016, 09:35 AM   #13
batman's Avatar
1964 22' Safari
modesto , California
I used the Honda oil for the 1st 50 hours for break in. Then switched to Mobil-1, on both my EU2000's. I change that once a year. No problems.
I am not sure what the Honda warranty department would say. However I do not expect to have any oil related issues.
Off topic: As far as mixing Mobil-1 and a conventional type of oil. Mobil, states it is no problem and can be done. I do not blend my oils I use straight synthetic. However my son has done this in his Toyota, with out issue. I know another friend who has done that in a pinch as well, with out issue.
-Dennis
batman is offline   Reply With Quote
Old 03-04-2016, 09:49 AM   #14
dznf0g's Avatar
Oswego , Illinois
Just to be accurate.
My Honda Shop manual says:
Change oil after first month or 20 hours. Thereafter change every 100 hours
"Recommended oil = SAE 10W 30 (-15* F - 110*F)or SAE 30 (50*F - 110*F) ; API service category SJ
-Rich-
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Anyone using Synthetic Oil in Honda Gen ? 2dabeach Generators & Solar Power 10 11-23-2010 05:12 AM
Vege oil in a honda generator??? silver suz LP Gas, Piping, Tanks & Regulators 27 06-09-2004 12:07 PM
Synthetic oil viscosities for heavy-duty towing ipso_facto Tow Vehicles 1 01-16-2004 07:04 PM
