Old 12-16-2015, 05:54 AM   #15
dznf0g's Avatar
Oswego , Illinois
Or we could just look in the owner manual:
"This engine is certified to operate on regular unleaded gasoline with a
pump octane rating of 86 or higher.
Never use stale or contaminated gasoline or an oil/gasoline mixture.
Avoid getting dirt or water in the fuel tank.
You may use regular unleaded gasoline containing no more than 10%
Ethanol (E10) or 5% Methanol by volume. In addition, Methanol must
contain cosolvents and corrosion inhibitors.
Use of fuels with content of Ethanol or Methanol greater than shown
above may cause starting and/or performance problems. It may also
damage metal, rubber, and plastic parts of the fuel system.
Engine damage or performance problems that result from using a fuel
with percentages of Ethanol or Methanol greater than shown above
are not covered under warranty"
-Rich-
Old 12-16-2015, 06:24 AM   #16
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ethanol has not been an issue for me except maybe a little hard starting after a period of disuse. But if you want to do the work you can take the alcohol out of the gasoline. I got this off the internet. How to Remove Ethanol From Gasoline | eHow
Old 12-17-2015, 03:37 PM   #17
2000 30' Excella
2014 30' Classic
Princeton , Iowa
Thanks I am at about 90% right.
larryglarson is offline   Reply With Quote
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 03:04 PM
Lifting 170 pound generator in and out of pickup bed? Any suggestions. Bandits Generators & Solar Power 41 02-24-2014 05:57 AM
Thinking about buying a Generator. Anyone have any suggestions? Blockstream Generators & Solar Power 16 07-19-2012 06:33 PM
Suggestions on Starting Generator after sitting 92landyacht Land Yacht/Legacy Motorhomes 30 12-04-2011 04:25 PM
