Old 11-24-2011, 03:36 PM   #15
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 59
You can use one Standard and one Companion (that's what we do) ... or two Campanions (but there's really no reason to do that)... With one of each you have everything... We have never used the 12v outlet on the standard (you need cables for it, too) to charge our batteries...as using the shore power cord and charging through the converter is more efficient...plus you have all the other 110 outlets live.
TB & Greg - Sadie Cocker & Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside AZBambi: AZBambi Décors
Old 11-24-2011, 03:36 PM   #16
r carl's Avatar
Lincoln , Ne
Originally Posted by idroba View Post
The Honda 3000 is the largest output and most quiet generator you can buy. As I recall, even quieter than the 2000 by a dB or so. It is remarkably vibration free.
Dont forget, most dependable and longest lasting, like a chevy.
Old 11-24-2011, 04:29 PM   #17
Mr & Mrs S's Avatar
Newton , Texas
One or two
I looked into the combo 2000s, I decided to go with one 3000 for the simple fact that I didnt want to have to keep up with hours for the two 2000s, oil changes for 2 generators, air filters, for two, and so on.
The 3000 powers our trailer just fine and I only have to keep up with one genny. This works for me, but others may not see it that way. Yes my genny is heavy but once its loaded in the TV it stays there.
No there are a lot of advantages to the two 2000s but to me there were just as many hassels as advantages.
So I kept it simple and have one genny.
But its all in what you want at the end of the day.
MR. & MRS. S
--Streamin & Gleamin--
Airstreamless, but havent lost our passion for them. Currently looking for the next project!
Mr & Mrs S is offline   Reply With Quote
Old 11-24-2011, 05:44 PM   #18
DKB_SATX's Avatar
1975 Argosy 24
Fort Worth , Texas
@Mr. S: We here in Texas have the dubious advantage of needing enough generator for AC 90% of the time, so it's not as much of a benefit for us to be able to take just one generator of the pair.
Il Carriaggio -- 1975 Argosy 24
2007 F150 Lariat Supercrew 5.4
AIR# 15566 | WBCCI# 15566
He has all of the virtues I dislike and none of the vices I admire.
-- Sir Winston Churchill
DKB_SATX is online now   Reply With Quote
Old 11-24-2011, 05:49 PM   #19
Mr & Mrs S's Avatar
Newton , Texas
Exactly! Very well put!
MR. & MRS. S
Old 11-24-2011, 05:59 PM   #20
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
We own 2 2000's. The only reason I had for buying the pair and not the 3000 was the weight. My tv will handle it but not the owner,at 73 loading and unloading a 3000 was way to much but would have rather had it.But the 2's I can handle and they do the job.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 11-24-2011, 07:32 PM   #21
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
I have a onda EU3000IS and I love it.Just got back from the past weekend Deer Hunting. It is quiet and I ran it over 7 hurs without filling it up. I still have gas in it.
Holds 3.4 gallons I believe...Amazing....Wasn't running the A/c the whole time, though. I was watching TV and Movies between hunts. I was running on Eco Mode.
If the weight is not an issue....Less filling of gens if your debating foing with 2. Also fill it up and you already have 3.4 gallons ahead,..then bring a spare gas can.
SHane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 11-24-2011, 11:40 PM   #22
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 59
Congrats! You made the right decision for your needs .... as it should be... the 3000 is a great machine... you'll enjoy how well it serves you...
Unit #3954
Honda EU3000is conversion to propane pickerdd Generators & Solar Power 2 10-02-2011 03:41 PM
Honda EU 3000i generator for sale rando Generators & Solar Power 2 05-12-2011 10:30 AM
Generator Plugged in took out Iota DLS 55 Hummer Batteries, Univolts, Converters & Inverters 10 04-30-2011 05:47 AM
Honda Generator Ramp Up henw Generators & Solar Power 7 04-17-2011 04:10 PM
Honda EU3000iS vs. Yamaha EF3000iSE/B pickerdd Generators & Solar Power 9 02-27-2011 08:24 AM
