Originally Posted by ljsigman
Mefly2,
Will I need dual aux caps and lines since there are two generators? What about a gas tank? I was looking at marine grade 6 gallon tank from Walmart.
We just have one aux tank because the second gen almost always settles to an eco/idle and doesn't use much fuel. If you have a higher current demand, then dual aux tanks might be in order. Most any portable marine tank will work well - just remember the larger the capacity, the heavier it is to move. Hence, we tend for the multiple smaller tanks for other fueling.
With regard to noise, two EU2000 gens are 3 db louder than just one. YMMV. However, we would like to have one EU 3000 semi-permanently mounted on a bedslide as well as keeping an EU2000 for portable use.
