Old 05-28-2016, 05:17 PM   #1
funkill's Avatar
Tucson , AZ
Images: 27
Honda eb2200x genny
I'm trying to determine if this will power my a/c.
Rated ampere - 16.7 A
Rated output - 2000 watts
Max output - 2200 watts
I don't know what my original a/c requires.
One page of service manual has a table for compressor Amos at low voltage:
100v - 15.4 a
110v - 12.5
120 - 10.2
Etc.
Laura
funkill is offline   Reply With Quote
Old 05-28-2016, 05:55 PM   #2
1973 31' Sovereign
Middletown , California
Not likely to get the compressor started with just the one generator, that's why they make the parallel kit. If you dialed in a soft start kit on the compressor and had a time delay on the fan and nothing else drawing current you might be able to run the AC on 1 2200 Honda but probably not a good idea. Best to get a bigger generator.
ijustlee is offline   Reply With Quote
Old 05-28-2016, 06:17 PM   #3
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
Hi Funki, One Honda 2000 usually won't start the air conditioners. The starting wattage will usually take two generators in parallel. They will run on one, but won't start.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 05-29-2016, 01:20 PM   #4
funkill's Avatar
Tucson , AZ
Images: 27
Thanks for the feedback. Was hoping that my 2200 would offer a tiny bit more than the 2000 to use the a/c this summer. ��
Wonder if It would power a small window unit. Hummmmm
Old 05-29-2016, 01:53 PM   #5
Images: 59
First, I don't think they make a parallel kit for EB generators.
Second, it's an EB 2200X generator, a different animal than a EU 2000.
Third, it depends on the size of your a/c.
I wouldn't give up on it yet.
Old 05-29-2016, 02:45 PM   #6
funkill's Avatar
Tucson , AZ
Images: 27
Yep, it's the heavy, loud EB2200X.
And I finally found my a/c size... per the 1973 Service Manual it's 12,000 btu. I think I might give up now.... dang, bigger than I thought.
Thinking that a smaller, new window unit might work, in a pinch.
Laura
Name:	honda EB2200X.jpg
ID:	263441   Click image for larger version
Name:	honda EB2200X specs.JPG
Old 05-29-2016, 02:51 PM   #7
Images: 59
I think with the much larger engine (almost 50% larger) in the EB2200X than the EU2000i, you will have no trouble starting and running a 12000 btu A/C.
Old 05-29-2016, 02:55 PM   #8
funkill's Avatar
Tucson , AZ
Images: 27
Wow - really?
I guess it can't hurt to try... any suggested precautions?
Laura
Old 05-29-2016, 03:16 PM   #9
Images: 59
1. Make sure the carbuerator is clean. If gummed up the generator will bog down and may lose power.
2. I add a little bit of Techron (feul injector cleaner) to the fuel. Seems to help but I don't know why.
3. Don't try to run any other appliances in the trailer while running the a/c.
4. You may want to look into a "hard start" capacitor for your a/c. Optional.
While these generators are noisier than the newer inverter types, they are still considerably quieter compared to the cheap contractor type generators.
Old 06-04-2016, 06:03 PM   #10
funkill's Avatar
Tucson , AZ
Images: 27
Well, today I finally got back to the Silver Olive and gave it a try...
Plugged in the trailer, started the generator and turned on the a/c (low, cool). The generator spat and sputtered and died. Then I remembered the refer and battery tender were still on. I unplugged each and gave it another try. Hallelujah! I could hear a strain on the genny but it kept up - and the a/c blew cold air. I switched the a/c fan to HI and the it still maintained.
I'm smiling. Now for the new little 2-way refer - and water pump - which I'll post in the associated boards.
Thanks for your insight.
Laura
5000 BTU/hr AC and 1,000 Watt Genny TouringDan Furnaces, Heaters, Fireplaces & Air Conditioning 37 10-09-2019 11:24 PM
Where do you start? First Genny, First Rally stowaways Generators & Solar Power 15 08-17-2010 12:21 AM
Good OR cheap genny? gowyn Generators & Solar Power 69 08-26-2008 07:50 PM
How often do you use your genny? gowyn Generators & Solar Power 26 02-13-2008 08:25 AM
