Old 06-19-2013, 11:25 PM   #15
withidl's Avatar
2002 31' Classic
Houston , Texas
Originally Posted by cwf View Post
I hope you are running the two off the same phase...
You can buy the adapter at any RV supply; been using it for years; must be OK.
withidl is offline   Reply With Quote
Old 06-20-2013, 05:22 AM   #16
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I could NOT run the Micro or Convection oven...and definitely NOT the AC or AC Fan.. I did not use the FRIDGE at all.
The fridge is about 3 amps max, so it's fine on this cord. We do it all the time, almost literally - we usually start our fridge before the first trip of the year (March-ish), then don't shut it down until after our Christmas trip.
Generally the only things I don't use when we're plugged in that way are the A/C and microwave. Otherwise I don't worry about it.
A general note: the converter can also draw some decent power if your batteries are depleted. Our 60 amp converter could draw 6 amps at 120 volts, or more if that 60 amp figure doesn't take into account the losses in the conversion. Normally it doesn't draw anywhere near that much, but it's worth mentioning as a potential high-draw appliance since we're talking about that and no one has mentioned it. (It's easy to forget about it.)
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-20-2013, 05:40 AM   #17
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
The Airstream website has a document that lists amperage of all of the common loads. Normal 15/20 amp service is good for anything except the AC and microwave, although the microwave by itself is fine. Never the AC, it might run but the voltage drop would force the AC to draw damaging current. If you want to run everything you need to install a true 30 amp connection through your home breaker box.
Larry
lsbrodsky is offline   Reply With Quote
Old 06-22-2013, 05:59 PM   #18
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
After I ordered my Airstream I began the process of preparing its "home" (which is now a really beautiful shed that was custom built for it). I installed a connection for my sewer, put a 4x4 post in concrete and mounted a water spigot so I'd have running water when needed, then ran a 30 amp line so I could have full electric out there and use my trailer as a guest house. I bought the outlet at Loew's and I've also seen them at Camping World. I will admit that is was quite a job running that line from my breaker box, but if I do something I like to do it right. (And I didn't have to worry about some yahoo putting in a 220 outlet when I needed 110, either!)
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 06-22-2013, 06:34 PM   #19
247stream's Avatar
1986 25' Sovereign
Cedartown , Georgia
oh thanks so much, once again I've fallen into a thread of much needed info! this forum is great
WBCCI# 1558
2016 Ram 1500 Crew Cab 5.7 Hemi
247stream is offline   Reply With Quote
Old 06-22-2013, 08:38 PM   #20
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Excellent! Getting our first AS this year and this has answered a future question
PharmGeek is offline   Reply With Quote
Old 06-23-2013, 08:08 AM   #21
mapleton , Utah
Another item worth mentioning is to make sure you have a good 3 phase charger/invertor if you plan to leave the batteries in the circuit. Otherwise you will ruin them in very short order as many here have discovered
I dont know what AS is using in the new units but if in doubt flip the battery disconnect switch when you are not actually charging and you should be fine.
tim
rumrunner is offline   Reply With Quote
Old 06-23-2013, 08:16 AM   #22
hissilver's Avatar
2018 25' International
Van Wert , Ohio
My brain just wobbled inside my head....
hissilver is offline   Reply With Quote
Old 06-23-2013, 09:16 AM   #23
SuperTrouper's Avatar
2008 27' International CCD FB
Petaluma , California
tim
I think "3 Stage" is a better term to describe a good charger/inverter as "3 Phase" conjures up big equipment in my mind. Also an FYI for newbies, when you are on shore power, flipping the battery disconnect switch on newer AS does connect/disconnect the batteries with a "click" but the indicator led does not change state. It's confusing at first.
Just nit picken this morning. Brad
SuperTrouper is offline   Reply With Quote
