Old 03-19-2018, 06:38 AM   #1
2017 27' Flying Cloud
London , Ontario
High voltage on Progressive EMS
Hi all,
I have the Progressive EMS PT-50 for protecting my trailerís circuitry.
Problem is, when I plug in at home and my sisterís house, L1 always reads a high voltage on L1 (as high as 220V) even though L2 reads normally (around 120V as expected). I have tested my mains and the multimeter reads 120 too so I am convinced the voltage on L2 is correct.
The power gets to the Progressive via a garage 15 amp circuit through two dog bones: 15 to 30a and 30 to 50a. I have tried two completely different sets of dog bones with the same result.
When I bypass the surge protector, everything electrical seems fine in the trailer.
Can anyone comment? When I hook directly into campsite 50a power everything reads normally. Is my problem with he surge protector, the dogbones, or something else?
Many thanks for any help!
Phil
Philip Jones is offline   Reply With Quote
Old 03-19-2018, 08:36 AM   #2
London , Ontario
To make matters more interesting, I now have plugged my electrical outlet tester into the RV and I find that it is reading open neutral. Does this help diagnose the problem?
Old 03-19-2018, 08:57 AM   #3
London , Ontario
Actually, I tried another tester and it states open ground. I have thrown out the other one as apparently one LED is not functioning.
Old 03-22-2018, 01:57 AM   #4
2016 30' International
redondo beach , California
How about some pictures of your setup with all the dog bones. That would help.
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 03-22-2018, 02:03 AM   #5
So for the record when I tried to do what you are doing my 50Amp Progressive device would not pass current because there was a ground fault detected. So when using 15A or 20A service I don't use the Progressive device.
Randy and Beth
Old 03-22-2018, 06:02 AM   #6
London , Ontario
Sorry but my trailer is in storage now so I donít have photos, but it was 15-30-50 with two dogbones.
Given your comment about the ground fault, perhaps I am better off just manually checking ďforeignĒ 15a outlets using my multimeter to ensure safety and then just using the Progressive for 30a and 50a services.
Progressive Dynamics EMS-HW50C billrector Electrical - Systems, Generators, Batteries & Solar 11 10-03-2017 05:20 AM
EMS from Progressive Industries markjoandall Electrical - Systems, Generators, Batteries & Solar 0 08-02-2005 08:14 AM
