Old 12-29-2017, 05:08 PM   #1
2016 30' International
redondo beach , California
High side shunt question
So with the AM solar kits the Victron BMV shunt is on the return side (-). Why not have a shunt on the high side (+) and float the current monitor? Then you could eliminate the DC/DC converter.
Randy and Beth
2015 F250 Titan 50 gallon
2016 30' International ProPride, EasyStart, Michelin 16", 400AH LiFePO4, Victron BMV 712, Orion DC/DC converter, BlueSolar MPPT 100/30, Victron 12|1200 inverter, 300W solar mix, Alpine iLX, Polk MM1, Samsung 42, one small air plant
mythbuster88 is offline   Reply With Quote
Old 12-29-2017, 06:11 PM   #2
2007 22' International CCD
Circuit is much easier to design with the shunt in the negative lead...reliable isolation is hard to do on the hot (+ lead).
Old 01-16-2018, 04:52 PM   #3
Bad question Mythbuster!
The DC/DC converter has nothing to do with the shunt used for current monitoring.
The reason for the DC/DC is to combine a travel trailer using LiFePO batteries to a tow vehicle charging system made for lead acid batteries.
Where is the "everything you need to know about a lithium battery upgrade" thread? And what else don't I know?
Randy and Beth
Old 01-16-2018, 05:14 PM   #4
Actually, thinking about battery charging hardware, components, and the like, I don't know of ANY that use a shunt on the high side (positive with respect to chassis ground).
Pretty much everywhere I've looked for battery monitors the shunt is on the negative side...
I'm guessing there is a pattern here--a few millivolts above ground is a lot easier to sense that a few millivolts bunches of volts above ground.
I worked in the datalogger and temperature measurement business years ago for a little company called Doric Scientific. We had systems that could sense precise millivolts while the thermocouple junction was up to 200 volts above or below earth ground. It had a nasty circuit inside the box that automagically took the signal conditioning box up to the common mode voltage. Company called it "AutoGuard".
We techs and engineers that worked on it called it "Auto Grab" because if the ground safety spring that was supposed to ground out that isolated section failed to make good contact, the circuit would go hard-over to at least +200 volts DC, and, yes, grab you and NOT let go. Once grabbed, forever vigilant...
So yeah, I like working closer to ground with the inputs...and I bet most other designers do to. Isolating stuff across a high voltage accurately is a real pain in the butt, just sayin'
hydraulic leveler question - how high is too high? JourneytoRet Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 12 04-06-2013 11:33 AM
Gas Prices for 2011 - How high is too high to tow? Kosm1o On The Road... 77 01-02-2011 09:48 PM
Anyone out there with ammeter/shunt experience? johnobuttons Lights - Interior & Exterior 2 08-16-2009 11:40 PM
TriMetric 2020/2021 shunt - 100 or 500 amp? ostream Electrical - Systems, Generators, Batteries & Solar 3 11-06-2008 02:37 PM
