Old 08-01-2006, 11:37 PM   #1
Hind-Sight's Avatar
Murray , Utah
Help with Wiring to Tow Vehicle
Last night I was trying to connect a 7 pin connection to my 69 Overlander as one of the PO's had replaced it with a 6 pin and only hooked up the brake lights, turn signals and running lights. No brakes and no charging.
I put it all together in what I think is right and when I plugged it into the TV, I heard some pretty good sparking so I stopped.
The brake lights, turn signals and stuff makes sense, but I want to clarify the Charge Line and the Ground Line.
While looking at the wiring up front of the coach, I see a blue wire coming from the left attached to the bolt of the plug cover. (Don't know if I am explaining this very well...) From there another wire looks like that is what was for the actual plug. I assume this is the charge line.
On the right side, I see two white wires attached to the bolt on the right side where another white wire comes off of. I assume this is the ground line.
If everything is hooked up properly, is it normal to hear sparking when plugging it into the TV?
The jist of this post is... HELP?!?! Any ideas on what I might have done wrong? What damage will I do if I have it wired incorrectly and just plug it in to really see what is happening?
Any troubleshooting tips would be appreciated.
Andy S.
Murray, Utah
69 Overlander
01 Suburban
Hind-Sight is offline   Reply With Quote
Old 08-02-2006, 12:10 AM   #2
C Johnson's Avatar
1965 17' Caravel
1968 28' Ambassador
Butte , Montana
Images: 326
Send a message via MSN to C Johnson Send a message via Yahoo to C Johnson
Try this : http://www.airforums.com/forum...ons-20279.html Also do a search on 7 pin wiring diagram
Also, sparking is bad !!
White "should" be ground but, two white wires ?
AIR # 7276, WBCCI # 7276
Photos of Project 2k5
Project 2k5
Life is a journey, not a destination
C Johnson is offline   Reply With Quote
Old 08-02-2006, 04:37 AM   #3
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Andy!
Airstream utilized wiring schematic that used neither the color coding or Bargman plug pin pattern common to today's tow vehicles. The link below will take you to a document that has the wiring pattern and color codes as used in 1969:
http://www.airstream.com/airstream/p...lug1966-81.pdf
The link below will take your to a document that has the industry standard that is typically found in most modern tow vehicles:
http://www.marksrv.com/wiring.htm
Good luck with your finding your wiring gremlin!
Kevin
Kevin D. Allen
AIR #827
Old 08-02-2006, 09:29 AM   #4
Hind-Sight's Avatar
Murray , Utah
Before starting the task, I searched here and used those very docs to point me in the right direction.
Hoping to get out there tonight and try again. I'll start by not connecting the charge line (or what I think is the charge line) and see what happens. I'll slowly remove pieces of the puzzle to troubleshoot where the problem is and then put it back together.
If it still doesn't work, I'll take pictures of what is there and see if that will spark (no pun intended) an idea of someone here.
Thanks for the responses, and hopefully, my next post will be a positive one.
Later,
Andy S.
Murray, Utah
69 Overlander
01 Suburban
Old 08-02-2006, 09:59 AM   #5
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
test the line that you are "assuming" is the charge line with a volt meter. If the battery is connected, it will have 12v on it.
the wires that are attached to the bolts on the connector are ground wires. one of them is the ground for the electric brakes.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-02-2006, 11:43 AM   #6
Aria's Avatar
1967 20' Globetrotter
Sauquoit , New York
We need help with our 1967 Airstream Globe Trotter. Wiring and electric brakes. Cannot open airstreamforums.com/forum...ons20279.html Would like to find drawings and directions to help us do the work ourselves. Thanks
Aria is offline   Reply With Quote
Old 08-02-2006, 12:03 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
have you tried hooking up an alligator clipped wire to the hot center post while plugged in to shore power...then testing the pins that are for the lights, etc? I di that and was able to see what worked right and what did not, and what needed only bulbs. If you get sparks then you know you are grounded out somewhere.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 08-02-2006, 12:08 PM   #8
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Car ( tow vehicle side)
1
white
10
common ground- same on trailer
2
blue
12
electric brake- to yellow on trailer
3
green
14
tail/running lights to green on trailer
4
black
10
battery charge (+) to blue on trailer
5
red
14
left turn/stop – to red on trailer
6
brown
14
right turn/stop to brown on trailer
7
yellow
14
auxiliary/back up- to black on trailer
trailer side
NEW CORD (yellow) --> TRAILER (black) : aux/back up
NEW CORD (black) --> TRAILER (blue) : charge line
NEW CORD (blue) --> TRAILER (yellow) : brake
Having a hrad time formatting this, let me know if it is not readable for you. I can email the diagrams
AIR #005
retired!
Old 08-08-2006, 09:55 AM   #9
Aria's Avatar
Sauquoit , New York
Car tow vehicle side..trailer side
Alansd in Roseell Georgia. Have made a copy of what you posted. If you can email to floyd5085@aol.com the diagram you suggested. Iam at work
trying to get the answers for my husband at home trying to make it work.
Thanks Anne
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 10:14 PM
Late Model Vehicle Tow Ratings Andy R Tow Vehicles 2 07-20-2008 07:11 PM
F250 tow vehicle or flatbed? Cheryl Tow Vehicles 19 08-23-2007 02:58 PM
Tow Vehicle Options wlanford Tow Vehicles 10 05-23-2005 01:18 PM
1975 Cadillac Eldorado as Tow Vehicle overlander64 Tow Vehicles 9 11-04-2002 08:04 AM
