Dave, if you're still watching this thread, I did look in that area under the 'L' part of the couch. On a 2014 model, The wires going to the breaker box were orange, two of them, and they looked like 12/2 romex, nothing special.
Leaving the breaker box was several yellow romex regular 14/2. Reason I say the yellow was leaving the breaker box is one of the yellow romex wires went right over the the hot water heater.
So I presumed the orange were going in the breaker box, even though I couldn't see where they come from.
I saw all the
12 volt DC lines leaving and the lines from the batteries.
I didn't have time to take top of the bench off. I will after we get back from out last trip of the season.
we store the AS inside at a somewhat heated storage facility, so I will work on it this winter. I'll be vacuuming that area out. You can store a good bit in there if you had too.
The subwoofer says made in Kalifornia. That's alright, they're still part of the USA right now.
I didn't see the transfer switch from Generator connector or AC shore power input, but I need to take that top of the bench off. I have enough room in the for a surge suppressor even if I need to re-route some wires.
thanks !
Have a good one ,
