Old 08-23-2007, 07:07 PM   #1
1983 31' Excella
Thomson , Georgia
Help with extension cord size
Had temporary power pole installed, pole is 100 yards from my 1983, 31' sovereign. What size and type of extension cord would be safe to run that far to plug in and power my trailer?
bgarrison is offline   Reply With Quote
Old 08-23-2007, 07:13 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
At the trailer you will want 110 volts, 30 amps. 110 volts. Hearing "30 amps" some electricians would automatically assume 220 volts -- don't do that. Our electricians will chime in here, but you'd lose a lot carrying that over 100 yards. Let's wait for a more informed response...
Great to have you here at AIR Forums -- thanks for searching us out!
5 meter Langford Nahanni
Old 08-23-2007, 07:17 PM   #3
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
How far is the pole from your panel? I had a plug installed in my garage about 80 feet from the panel and the electrician used 10 guage. Can you move the pole closer to the trailer? You will need at least 10 and possible 8. The wire size has been discussed recently in another thread.
Bill
Just my personal opinion
wkerfoot is online now   Reply With Quote
Old 08-23-2007, 07:21 PM   #4
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
this Voltage Drop Calculator JavaScript wire calculator says you need #2 awg.
i don't think you will find an extension cord that big unless you have "connections".
getting closer to the supply is a better idea.
john
you call them ferrets, i call them weasels.
Old 08-23-2007, 08:07 PM   #5
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Need more info. Do you have a 30 Amp or 50 Amp connection on the trailer, I guess it's 30 amps.
Do you plan to run the Air Conditioner? These are all questions that need to be answered. John H D is correct for a full load.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 08-23-2007, 08:10 PM   #6
Desert Fox
1985 31' Sovereign
Tucson , Arizona
Smile Hi Garrison
Can you move your rig closer? If not can you run a#2 wire cable under ground and bring it to the plug?
Regards Russell in Tucson Az.
RUSSELL is offline   Reply With Quote
Old 08-24-2007, 05:34 PM   #7
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I think the short answer is: the same as your trailer cable. But I think you need a longer one (answer, that is) - so you will need to know what your planned load will be and figure from there.
And distance is critical - as these folks recommend, see if you can get closer, because the short answer is expensive at 100 yards.
Pat
pmclemore is offline   Reply With Quote
Old 08-24-2007, 07:14 PM   #8
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
100 yards, is 30 feet. one guage size down from standard for every fifty feet. so six guage sizes down from standard. 10 guage is standard for 30 amps.
so 8,6,4,2,0,00 the answer is 00.
Michelle TAC MT-0
Sarah, Snowball
Old 08-24-2007, 08:25 PM   #9
empresley's Avatar
1984 34' International
1977 Argosy 24
Central , Georgia
How temporary?
Do you have a rural EMC or city elec. dept.? They might have some wire you could use for a temporary feed. 300 feet is a long run & will need wire size not associated with extension cords.
We have a 200 amp panel that we use as a main service and from there we take 220v service for 100 ft. (using #4 wire) to serve a secondary 100 amp panel that serves our Airstream & shelter. It is at the 100 amp panel that we convert down to 110v / 30amp breaker for the trailer.
A small 50 amp panel might work to switch from 220 to 110 for your final service to the Airstream.
Travelers by aluminum roadships, loyalists to one species,
masters of convenience, herdsmen steeped in maintenance and restoration.
empresley is offline   Reply With Quote
Old 08-24-2007, 09:08 PM   #10
Keymar , Maryland
I can't count
100 yds is 300 ft!
the first fifty is good at 10 Guage the final answer is 0 guage to be safe.
Michelle TAC MT-0
Sarah, Snowball
Old 08-25-2007, 01:10 AM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i can't count either michelle, that is why i use the calculator.
you must be thinking 0% line drop, were you thinking aluminum or copper?
john
Old 08-26-2007, 08:54 PM   #12
Keymar , Maryland
0% line drop is best. motor starts will cause a significant load and drop which is hard on the motor.
Michelle TAC MT-0
Sarah, Snowball
awning polycord size sovereign Awnings 5 04-23-2012 11:38 AM
Stand up power cord Happycampers Electrical - Systems, Generators, Batteries & Solar 0 04-18-2004 07:03 AM
Phone cord Joan D'Andrea Cabinets, Counter Tops & Furnishings 0 11-02-2002 10:38 AM
tow ball size iguana Hitches, Couplers & Balls 2 10-03-2002 11:39 AM
Size of black water tank glyoungca Waste Systems, Tanks & Totes 3 06-10-2002 04:17 PM
