The wires are to the outside sensor for the temp display on the control panel. If the external sensor is bad, it probably reads -40 on the display. As far as I know the sensor isn't available from Airstream, but I hope I'm wrong. You can find other sensors that will function with that system, but with the availability of inexpensive, wireless remote systems, I'm not sure it's worth the effort/expense. If it works correctly, leave it alone. If it doesn't (shows -40) you can either try to replace the sensor or cut the wires and tape them up. If you choose that option, leave them as long as possible and as close as possible to the opening in the belly, maybe with a retrieval string attached. If they are not long enough to reach the opening, splice some additional wire onto them so that at a later time, should you choose to do so, you can clean away the sealant around the opening and pull them through to outside to attach a new sensor. That's what I did. Best of luck.
