Old 05-05-2015, 12:02 PM   #1
1987 34' Limited
New Orleans (for now) , Everywhere
Help us identify these wires please!
Hello! We are renovating a 1987 34' Limited and we are currently replacing a few areas of the subfloor and have found some unidentified wires and what seems to be a plastic piece holding them together. It is located in the front on the passenger side. Since the small piece holding them together is sticking out of the belly pan a tiny bit we thought it might be a thermometer of some sort for the control panel? Not entirely sure. So I was wondering if anyone knew what these wires are for and where/if we can purchase a new plastic piece?
ID:	237847   Click image for larger version
dillonation is offline   Reply With Quote
Old 05-05-2015, 12:10 PM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Looks like a ground wire to me.
BambiTex is offline   Reply With Quote
Old 05-05-2015, 12:11 PM   #3
I believe it's the sender unit (sensor) for the external temperature gauge on the control panel. If it's like mine, the temperature gauge is switchable between internal and external temperatures. My similar internal sensor is underneath the shelf supporting the radio. The temperature gauge has adjustable calibrators, but mine are so sensitive as to be unusable.
Nick
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 05-05-2015, 12:12 PM   #4
1987 34' Limited
One more thing: It has a brown, orange and red wire connected to it.
Old 05-05-2015, 12:16 PM   #5
If you remove the control panel you will see these two colored wires entering the back of the temperature gauge.
Nick.
Old 05-06-2015, 10:41 AM   #6
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
The wires are to the outside sensor for the temp display on the control panel. If the external sensor is bad, it probably reads -40 on the display. As far as I know the sensor isn't available from Airstream, but I hope I'm wrong. You can find other sensors that will function with that system, but with the availability of inexpensive, wireless remote systems, I'm not sure it's worth the effort/expense. If it works correctly, leave it alone. If it doesn't (shows -40) you can either try to replace the sensor or cut the wires and tape them up. If you choose that option, leave them as long as possible and as close as possible to the opening in the belly, maybe with a retrieval string attached. If they are not long enough to reach the opening, splice some additional wire onto them so that at a later time, should you choose to do so, you can clean away the sealant around the opening and pull them through to outside to attach a new sensor. That's what I did. Best of luck.
fwjumper is offline   Reply With Quote
Disconnected wires, help to identify cclaybrook Electrical - Systems, Generators, Batteries & Solar 0 02-22-2015 07:24 PM
Will someone identify these please Bex Belly Pans & Banana Wraps 4 09-26-2013 08:27 PM
Please help me identify what model this is freeofecho Our Community 9 10-22-2010 07:12 AM
Help Identify my new trailer please kstampa Vintage Kin 10 06-05-2010 08:18 AM
Airstream or not? Please help IDENTIFY! fcavolijr General Motorhome Topics 20 09-22-2009 10:49 AM
