I need to replace the 'Panel Display' switch on my Solid State Control Panel. My old one worked fine (and panel displayed good) until my wife pushed the switch too hard and broke it...
Can I solder any
12v switch as a replacement? What can I use as a replacement? Is this something that I can simply solder in?
As a temp solution, I was thinking on soldering 2 wires and simply touch the wire ends together (manual switch) to display the tank status. Can I do this or is it not recommended?
