Old 06-08-2015, 05:18 PM   #1
Los Lunas , New Mexico
Help! Replacing Univolt in '73 Overlander
I have a 73 Overlander. Doing a complete remodel. I'm replacing the Univolt with a PD 9200, Common Block and Fuse Panel. To complicate things, I have the 12 V Onan Generator. I'm trying to keep it as simple as possible (do it myself, as opposed to paying someone $800). Has anyone done this and taken pictures? Any advice would be peachy.
mdritt is offline   Reply With Quote
Old 06-08-2015, 06:32 PM   #2
1979 23' Safari
Wayland , New York
Does the univolt have wiring going to the fuses on it or are they in a separate fuse panel? If they're separate this should be very easy.
Disconnect battery and unplug the univolt. Cut the pos and neg cables coming from the univolt, try to keep them as long as you can for slack installing the PD. Take out the univolt. Put the PD 9200 in its place. Strip the ends of the old positive and negative and install into the positive and negative sockets on the PD 9200 and tighten the Allen screws. Plug in the PD 9200 and you're done.
Old 06-09-2015, 11:23 AM   #3
Univolt to PD9200
Thank you for the response. No, the fuse block is built in to the Univolt.Click image for larger version
Old 06-09-2015, 10:26 PM   #4
1979 23' Safari
Wayland , New York
In the proverbial words of Charlie Brown, Uggggg. Ok still not terribly difficult, but you'll have to replace the fuse block on the univolt with something else if you replace the univolt.
Need a few parts, grit, spit, and a whole lotta duck tape.
Just helped a few guys get through this, take a look through this post; http://www.airforums.com/forums/f37/...ck-135473.html , and this one http://www.airforums.com/forums/f219...er-133233.html. They'll get your mind moving in the right direction.
Good news is that it looks like you've got some room to work with down there, and new converter is much smaller than the univolt.
Think you may recognize the fuse panel in the first post.
Replacing univolt with solar panel system-newbie needs help keithgregg Generators & Solar Power 14 06-21-2015 09:05 PM
To Univolt or NOT Univolt? aircooled4 Batteries, Univolts, Converters & Inverters 11 05-13-2012 07:20 PM
Help - Replacing Univolt - Which Wires? tkasten Batteries, Univolts, Converters & Inverters 26 03-29-2011 01:48 PM
Replacing Univolt and old line/battery switchbox this weekend JMoy Electrical - Systems, Generators, Batteries & Solar 1 08-23-2006 06:24 PM
Replacing Univolt and 12V confusion sander17 Batteries, Univolts, Converters & Inverters 8 06-29-2004 09:09 AM
