Old 06-18-2019, 07:20 PM   #1
1973 31' Sovereign
browntown , Virginia
Help power for elect/lpg water heater
Hi-
Unfortunately my 75 sovereign i just listed for sale needs a water heater. Thinking of upgrading to electric and propane but where can i pull power? There is a 110 outlet under sink in front the converter is plugged into and the outside outlet is accessible there as well - could i run via one of these? The elect. panel is opposite the bathroom in wardrobe so getting to it is problematic. Or i just put propane back in but time is crucial as i have someone interested.. Help please and thank you
onecompton is offline   Reply With Quote
Old 06-18-2019, 07:42 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
The electric water heater element should be on a separate breaker. I think they spec a 15 amp breaker.
Cheers, Dan
~ Margaret Thatcher ~
Old 06-18-2019, 07:53 PM   #3
1973 31' Sovereign
thanks
I figured as much, without pulling the belly skin to run wire to the other side of the hallway i see no way then of doing this. I just want everything to be sorted for the next owner so i guess its propane only for now.
Atwood Gas/Elect hot water heater - Electrical problem with suzieleigh Water Heaters, Filters & Pumps 2 08-17-2015 08:11 PM
Elect/Propane Water Heater Combo dkottum Plumbing - Systems & Fixtures 4 12-11-2011 05:41 PM
Humming / buzzing when hooked up to elect likable_1 Batteries, Univolts, Converters & Inverters 3 08-23-2011 11:42 AM
HELP Please! Just got it home, elect issues? swanky Batteries, Univolts, Converters & Inverters 34 06-15-2009 09:17 PM
Hot Water/ Furnace..Elect or Gas?? Jim Casavant Furnaces, Heaters, Fireplaces & Air Conditioning 1 08-06-2007 08:42 PM
