Old 09-02-2013, 01:54 PM   #1
2012 25' International
Help! No Electrical Power inside 2012 A/S Int.
Have a 30 amp plugged into my A/S the power light indicator is on but everything is dead inside. Breakers are on. What am I missing?
Thanks in advance!
Tom in Austin
h8rain is offline   Reply With Quote
Old 09-02-2013, 01:56 PM   #2
1974 Argosy 20
Kooskia , Idaho
Is the use/store switch in the Use position?
Old 09-02-2013, 02:06 PM   #3
Yes, it is in USE position.
Old 09-02-2013, 02:12 PM   #4
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
If you haven't already, manually flip all breakers to the off position, then return them to on and keep your fingers crossed.
Greg
Roadtoaster is offline   Reply With Quote
Old 09-02-2013, 02:16 PM   #5
No joy. Reset breakers. Could this be a blown inverter?
Old 09-02-2013, 02:19 PM   #6
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Your use switch doesn't need to be on when connected to 30 amp. My bet is you have a tripped breaker because of the source. If you have a surge protecter, use it, and make sure it trips when you test it.
But first, an obvious question... Is the source 30 amp on?
Recycle the breakers at the source, and in the AS.
Old 09-02-2013, 02:25 PM   #7
Free Range Human
Drathaar's Avatar
Twin Rocks , Oregon
That would be a converter... AC-> DC
With external off, do you have DC when the use switch is on?
I sent a PM with my cell if you want to talk.
Old 09-02-2013, 02:53 PM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Does the microwave, TV or air conditioner work?
These are separate from the battery/convertor circuits and will confirm you have 120 volts into the trailer.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-02-2013, 02:57 PM   #9
No power to anything inside.
Old 09-02-2013, 02:59 PM   #10
jdalrymple's Avatar
Jay , Oklahoma
Breaker on the post you are plugged into?
Some folks always turn the breakers off at the post when unplugging their shoreline.
JD
Jeff & Cindy
'91 350 LE MH
Old 09-02-2013, 03:18 PM   #11
2011 25' FB Flying Cloud
Anywhere & , Everywhere
Transfer switch problem? You have 2 elec inlets on the trailer - have you tried both? If not suggest you do so. The transfer switch problem has been covered in a number of other threads which you should be able to find with a search.
Al - K4GLU is offline   Reply With Quote
Old 09-02-2013, 03:27 PM   #12
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Agree that it has all of the symptoms of a transfer switch problem. Your LED on the cord will be on but you will not have power to the breakers and converter.
Larry
lsbrodsky is offline   Reply With Quote
Old 09-02-2013, 03:34 PM   #13
Nothing works. No micro, battery power to jack, TV or Air Conditioner.
Old 09-02-2013, 03:36 PM   #14
Will try front plug on trailer.
