Old 09-02-2013, 03:47 PM   #15
2012 25' International
Genius award to transfer issue!
Didn't have enough reach to try the 30 amp so put on the 110 connector and hooked to front plug-in and immediate power inside.
h8rain is offline   Reply With Quote
Old 09-02-2013, 03:49 PM   #16
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
Good call.
My '09 just has one, and I always miss that.
Glad it is working. That is a known issue, and warranty will cover it.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-02-2013, 03:54 PM   #17
These little bugs are the worst thing and the best about Airstream! Thanks to everyone for helping me! Austin, Texas has a cold beverage on me waiting for my Airstream instructors!!!
Thank you,
Tom
Old 09-02-2013, 04:18 PM   #18
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Cool beans and good news!!! You might consider picking up a 25 foot, 30 amp extension. Mine has come in handy a time or two.
I agree, genius award to AL - KG4U.
Are you getting DC to the batteries now, so that the jack is working???
Old 09-02-2013, 04:22 PM   #19
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Make sure you see the transfer switch replacement. There apparently have been several failing. In one guys AS repair to main wiring was needed.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-02-2013, 05:04 PM   #20
No sooner did I step in the house, the front 110 plug apparently blew (blue LED light on front plug-in was out). Decided to try the rear again. Plugged the rear into the 30 amp and A/C is working etc.
Seems pretty finicky. The electrician who installed the 30 amp is coming tomorrow and will see if he's got an idea?
Old 09-02-2013, 05:06 PM   #21
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
The TS Airstream uses, not the best quality..
Still under warranty? I would negotiate for an up-grade.
It's not an uncommon problem.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 09-02-2013, 05:16 PM   #22
amaier7771's Avatar
2013 25' FB Flying Cloud
Colorado Springs , Colorado
I have a 2013 Flying Cloud 25FB. Last weekend we were camping and all of sudden everything went dead. flipped all breakers, checked everything and nothing. Then I moved the shore cable to the front connector and everything worked!! Took it in for warrantee service and they told me the Transfer Switch was blown and a new one on order from Airstream. Hope to get the AS back before next weekend!!!
amaier7771 is offline   Reply With Quote
Old 09-02-2013, 05:39 PM   #23
Transfer Switch works for short time and then quits on the rear 30 amp plug-in. Hope that Camper Clinic II wants to order the replacement for me without hauling the thing to
Buda!
Old 09-02-2013, 06:05 PM   #24
If they replace it in kind, a good chance it will fail again in kind.
PFC
"Tahawus"
RLC
John Prine
Old 09-02-2013, 06:45 PM   #25
My original transfer switch failed, dealer replaced it and then that one failed. I am on my third transfer switch counting the original.
2012 Flying Cloud 25 FB
Scaler113 is offline   Reply With Quote
Old 09-03-2013, 08:14 AM   #26
jdalrymple's Avatar
Jay , Oklahoma
Random thought: Make sure the electrician knows you want a 120 VOLT 30 amp circuit.
I am not being picky here, but in the quoted post you mentioned trying the the "110 " plug. I understand this may just be a terminology thing during the heat of battle, but more than one Airstream has suffered damage from an incorrectly wired 30 amp RV outlet.
Regards,
JD
Jeff & Cindy
'91 350 LE MH
Old 09-03-2013, 03:59 PM   #27
Took my 2012 A/S international 25 RB to Camper Clinic II today. It won't be looked at until next week. To order parts, I assume. Service date would be about a month away due to backlog!
Must be hunting season?
Old 09-03-2013, 04:11 PM   #28
Regards,
JD
JD,
I don't know electricity, but thought the standard plug was 110 volts? So what I meant was I used the adapter for a regular outlet (three-prong) to test for power because my 30 amp plug wouldn't reach without an adapter & extension cord to a standard outlet. It did blow the circuit breaker. Then I went back to the 120 volts / 30 amp plug. The A/C and lights worked for a short while and then quit too.
Will let you know the diagnosis.
Tom
