Old 05-24-2005, 02:45 PM   #1
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
HELP!Need info tonight.
I am acually pulling wire and getting ready to assemble stuff again.
I need to pick up some stuff but I need some sizes.
I want to prewire for a Winguard and run a coax from one end to where I will hook up if I go to a place that has cable available. What size coax and power requirments will the Winguard need? I am just going to leave a pig tail in a handly locatin in the exterior gear locker for the Cable.
I am prewiring for a A/C as well. What size hose do I need for the drain line?
I am pulling new power for the A/C and all outlest. I will just leave the lighting on the existing wires. Already prewiring for a CD player and speakers.
Running power for my 12v and a Intelapower.
ANything else I am forgetting before I put the ceiling back up and put in the lower walls?
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 05-24-2005, 03:22 PM   #2
Over59's Avatar
Putnam , Connecticut
Images: 37
Are you using Marine grade or other stranded wire or solid?
I think there are only two sizes coax, 5 and 6. 6 is better and will work with that DirecTV setup you'll get someday.
http://www.wildtracks.cihost.com/hom...html#wire_coax
Over59 is offline   Reply With Quote
Old 05-24-2005, 03:30 PM   #3
Images: 59
Eric the plumber,
The drain hose for the Penguin is 1/2" ID. TThat's the size of the hose barb on the drain tray.
Do you plan to add a greywater tank? Think about putting in a tank vent, 1.25".
Old 05-24-2005, 03:32 PM   #4
Got gandkids?
Jim & Susan's Avatar
'Possum Holler , Georgia
Toaster, I can help with a couple of these. CATV used to be RG-6. I think they are now useing RG-59. The guys at Radio Shack/HD/Lowes can give you the skinny. If all else fails, look at the stuff on the side of your house. There are a couple of threads on this subject I've read here, one of them had a cool connection "box" that you can mount on the outer skin on the TT so that you don't have a pig tail flopping around.
I think the a/c drain is a 3/4 inch. I can measure, but it's gonna be a few hours before I can get to it.
Just curious, what are you using to hold the wire in place against the skin of the camper? I'm looking for a suitable replacement for those grey "keepers" they used way back when.
www.nesa.org
Air No. 6427
Old 05-24-2005, 03:35 PM   #5
Over59's Avatar
Images: 37
RG-6 if the better cable and the only one to be used with a digital signal.
Old 05-24-2005, 03:37 PM   #6
Images: 59
Exclamation
Jim,
This is the method they used in 1959.
ID:	12382   Click image for larger version
Old 05-24-2005, 03:41 PM   #7
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
other way around.
RG-6 is thicker than RG-59, so the connectors are different. but they fit the same "F" connectors on the back of your tv...the other ends that fit on the cables are bigger.
the satelite stuff requires the rg-6. I also found that running digital cable at my house, it didn't like the rg-59. switch the cable to rg-6, and the problem was solved.
fwiw: I just bought a winegard antenna, and it came w/ a length of rg59. which is fine for tv signal to an antenna.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 05-24-2005, 03:54 PM   #8
87MH's Avatar
1978 31' Sovereign
Images: 292
Eric the Electrician
If even the most remote possibility of a media center has crossed your mind, throw in a couple of sets of Monster Cable speaker wire - how about an internet connection?
I know that the coming thing seems to be Wi-Fi, but an extra cable and phone connection will not add any weight -
Might as well..........put it ALL in while it's open.
.....on the AC drain line - slightly bigger is better - IF a critter (or other nasty) gets caught in the line perhaps a larger ID will permit a "snake" to be run up the hose in order to dislodge the obstruction.
Luck.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 05-24-2005, 03:57 PM   #9
Got gandkids?
Originally Posted by markdoane
Jim,
...Looks like some of the work I did on my first car as a teenager!
www.nesa.org
Air No. 6427
Old 05-24-2005, 03:59 PM   #10
Images: 59
Did you work at jackson Center?
Old 05-24-2005, 04:05 PM   #11
Got gandkids?
No, at least not that I remeber! I was referring to these things used on the '70's trailers used to hold the wire/wire bundles in place agianst the interior side of the outer skins.
www.nesa.org
Air No. 6427
Old 05-24-2005, 04:10 PM   #12
Images: 59
Jim,
Those are called Cling-ons.
Old 05-24-2005, 06:44 PM   #13
If my memory is still working, Rg 6 and Rg56 are 50 ohms cable used for radio communication with the Rg6 being heavier gage for lower losses while transmitting high power. Not much difference can be noticed while receiving a signal unless the length is very long. Rg 9 and Rg 59 are 75 ohms impedance cable used for tv signals such as cable, dish, etc. Impedance is very important for lower losses so don't use the wrong one. That was a penny's worth.
FrenchBern is offline   Reply With Quote
Old 05-24-2005, 08:13 PM   #14
Got gandkids?
Alright, I went out and measured the A/C drain line. It's 1/2 inch inner diameter. Let me know if you need pictures. This is for the original Armstrong A/C that came with it. Take care, Jim.
www.nesa.org
Air No. 6427
A/S Info ? well some good FrankR Our Community 2 05-13-2014 08:33 PM
Other A/S info sharing sites Rog0525 Our Community 12 10-18-2002 10:09 AM
GREAT TECH INFO - good advice COArgosy78 General Repair Forum 6 10-11-2002 01:08 PM
Airstream info Rodger Airstream Motorhome Forums 3 07-03-2002 09:15 AM
Need info on A/C unit on a 1975 26 ft Argosy ... Hayseed Argosy Motorhomes 0 06-27-2002 08:19 AM
