Old 08-22-2008, 05:19 PM   #1
1965 22' Safari
memphis , Tennessee
Help identify this electrical component
hi, i have been working on a floor replacement and just got to the front part of the trailer. this is a '65 safari. the umbilical cord comes into the trailer here and a couple of the wires are attached to a square or rectangular box. can anyone tell me what this thing is and if it is needed? the wires look like they've been chewed by mice or just worn out. surprisingly enough when i bought and towed home the brake, tail light, and turnsignals all worked fine...as did one of the forward running lights.
thx for any insight!
bob
rburditt is offline   Reply With Quote
Old 08-22-2008, 05:23 PM   #2
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
Does it come in from the front or back?
mustang is offline   Reply With Quote
Old 08-22-2008, 05:24 PM   #3
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
It almost looks like the plug from the tow vehicle and someone had a short so they cut and redid the connection
Old 08-22-2008, 05:25 PM   #4
mustang's Avatar
1986 31' Sovereign
Kent , Ohio
My trailer has a plug in the front for the cord and the back side is hard wired seems like they eliminated that plug threw the skin????
Old 08-22-2008, 05:58 PM   #5
zamboni's Avatar
Are you asking abouthe little "box" with two wires attached to it...looks like a heavy duty circuit breaker (used instead of a fuse).
zamboni is offline   Reply With Quote
Old 08-22-2008, 06:10 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
It's a circuit breaker
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 08-22-2008, 06:16 PM   #7
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
What color are the wires (they look white to me) if so this is the frame ground conection.
Ramp is offline   Reply With Quote
Old 08-22-2008, 06:38 PM   #8
GreatPumpkin's Avatar
Colville , Washington
Images: 70
Ditto on the circuit breaker - I had the same thing in my '64 Overlander.
AIR 12256
Currently Looking
2001 Dodge Ram 1500
2001 Honda XR650R
Currently Looking...for an Avion Truck Camper (or a Classic Argosy MoHo)
"In regione caecorum rex est luscus." GP
GreatPumpkin is offline   Reply With Quote
Old 08-22-2008, 09:03 PM   #9
1965 22' Safari
memphis , Tennessee
circuit breaker?
do i need this circuit breaker? what did all of you do w/ yours?
Old 08-22-2008, 09:05 PM   #10
Excella CM's Avatar
Venice , California
It's there to protect the wiring. Leave it in.
Old 08-22-2008, 10:05 PM   #11
1965 22' Safari
memphis , Tennessee
circuit breaker?
its so corroded, how do i know if its functioning properly? is there a more modern solution that might be better??
Old 08-22-2008, 10:09 PM   #12
damonbeals's Avatar
1998 31' Excella 1000
1979 23' Safari
Mooresville , Indiana
They still use these types of circuit breakers, you should be able to pick one up at most automotive part places.
damonbeals is offline   Reply With Quote
Old 08-23-2008, 06:47 AM   #13
1965 22' Safari
memphis , Tennessee
does that mean there it is pretty generic and no specs that i need to be aware of when i try to find replacement?
Old 08-23-2008, 07:21 AM   #14
richinny's Avatar
2011 34' Classic
you just need to match the amperage rating.
Ricky
Can anyone identify what I have marvin 1954 - 1959 Overlander 42 12-31-2009 10:12 PM
Help identify cosmotini Off Topic Forum 17 01-04-2008 11:22 PM
Can Anyone Identify? rhoward Airstream Trailer Forums 12 12-11-2007 06:42 AM
A Possible Addition : Please Identify flamingo-kid1 Our Community 12 07-27-2005 07:37 AM
'95 Classic Headlights: COMPONENT or SEALED? Griffin Mechanics Corner - Engines, Transmission & More... 1 02-07-2003 12:16 AM
