Old 04-25-2019, 03:57 PM   #1
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Help! Electrical Problem, Bathroom Exhaust Fan
While getting the trailer ready for summer, I found that the Ventline exhaust fan in the ceiling of the bathroom was not working. I put a voltmeter across the terminals on the motor, switched the rotary switch off and on, and got no readings. I figured the switch was bad and ordered a new one.
After installing the new push button replacement switch, the fan still is not working. This time, I unhooked the wires from the terminals and measured 12 volts on the two wires. I then ordered a new motor figuring it was the culprit. Before installing, I hooked the new motor to the circuit for the fan. It did not work! I then measured the voltage between the two wires. It was 12 volts and I could turn the electricity on/off with the new switch.
Now, I am quite perplexed. I have voltage, but neither the old nor new motor will work attached to the fan circuit, so I tested the motors. When hooked to a separate 12-volt power source (one of the cigarette lighter outlets), both of the motors worked!
I have checked and replaced the crimp terminations for the fan wires to the main wireharness (figuring I might have a high resistance connection). I still measure 12 volts between the wires, but the motors do not run on the fan circuit.
One interesting observation. When I measure across the terminals of the motors when hooked up to the fan circuit, I get zero volts. When I measure across the motor terminals when hooked to the separate power source, I get 12 volts.
Help! I am pretty good with electrical systems, but this issue is definitely beyond my understanding/experience.
Thanks.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 04-25-2019, 04:40 PM   #2
Fort Davis , Texas
Volts don't make the motor run, amperage (power) does. You can have a voltage measurement of 12V with a circuit that can only provide a few mA of power. Not enough to run your motor. Check the fuse on the circuit and if you have an ammeter put a resistive load on the circuit and see how many amps you are drawing.
Just a thought,
Pat
pdavitt is offline   Reply With Quote
Old 04-25-2019, 07:01 PM   #3
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Pat,
Thanks for your input. I have checked all of the circuit breakers. Could not find any issues there. I do not think there would be any inline fuses in this part of the body wire-harness (but who knows...).
I ordered a new meter yesterday with more capabilities. I will do some of the tests you are suggesting this weekend.
DaveP
Old 04-25-2019, 07:13 PM   #4
Fort Davis , Texas
Originally Posted by DaveP View Post
I have checked all of the circuit breakers. Could not find any issues there. I do not think there would be any inline fuses in this part of the body wire-harness.
Check the wiring diagram for your unit. There should be a DC fuse block somewhere.
Pat
Old 04-25-2019, 07:27 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Try using a known common/ground connection on one side of the motor.
In other words put a jumper on one of the motor leads that is connected to the skin/chassis.
Then connect the switch to the other lead on the motor.
If the motor runs. You have a bad common/ground connection.
TG Twinkie is online now   Reply With Quote
Old 04-26-2019, 10:41 AM   #6
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Pat - I checked the wiring diagram. There are no extra fuses shown in this circuit. It goes back to the DC circuit breaker box in the front.
TG - I tried the common ground. The motor did not run.
At this point, I am waiting for the new meter to arrive this afternoon. Let me know if you guys think of anything else.
DaveP
Old 04-26-2019, 11:20 AM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
You may have a fuse which cooked itself. You will read voltage on a meter because of the high input impedance.
Whereas the motor will cause a voltage drop across the carbon track of the cooked fuse.
Are these the modern blade fuses or the old glass units?
Old 04-26-2019, 12:22 PM   #8
2019 25' Flying Cloud
spring hill , Florida
Hi, I had the same problem when I first purchased our 25" RB. first check to see that the other devices further down on that circuit work ie. reading lights USB ports ( those are on that circuits line for my RB 25). You can check whats listed on that circuit on the breaker box or go to the Airstream wiring diagram for your Trailer.
We had a wiring harness connector loosen up that serviced that circuit. It was located behind our Microwave,it was under warranty and the tech only had to reconnect firmly and reinforce the connector with tape... Fixed
Best of luck hope this helps
sleepy57 is offline   Reply With Quote
Old 04-26-2019, 07:07 PM   #9
DaveP's Avatar
2004 28' Classic
Monument , Colorado
The system in my Classic uses circuit breakers, not fuses (although I have found a few inline fuses in different circuits. Everything around the fan seems to be working, so no easy clues...
DaveP
Old 04-26-2019, 08:21 PM   #10
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
Just a thought,
Pat
"Volts don't make the motor run, amperage (power) does." - Partially true. The circuit voltage and the motor resistance determine the current. The motor will not draw the right current unless the proper voltage is present.
"You can have a voltage measurement of 12V with a circuit that can only provide a few mA of power. Not enough to run your motor." - Partially true. Only when measured open circuit. If the circuit can only supply a few milliamps the voltage at the fan with the switch on will be only a few millivolts.
Depending on the type of fan you have there are things in the circuit other than the on/off and speed switches that can cause the fan not to run:
1. If it is motorized (to open/close) there is a limit switch that will not let the fan turn on unless the lid is open a certain amount.
2. If it is auto-close, there is a moisture sensor that runs off fan power and closes the lid. IF it is shorted the lid will not open and the fan will not run.
3. Some fans have a thermostat. If the inside temperature is lower than the thermostat setting, the fan will not run.
To get to the problem:
Measure the voltage between each motor terminal and a known good ground with the switch on.
If the plus side of the motor reads close to 0V, then you have a bad 12 V feed. Go backwards through the wiring until you find 12V. When you do you have just jumped over the bad part.
If the voltage on the plus side reads 12V and the voltage on the ground side of the motor reads close to 12V you have a bad ground connection somewhere between the motor and ground. Some of the components mentioned above may be in the ground side of the motor. Go backwards through the circuit until you find 0V. When you do you have just jumped over the bad component.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 04-26-2019, 09:02 PM   #11
Oops
Al
I misread the OP's post. For some reason I thought he was talking about a cabin vent fan. Below I have deleted the part about the other components.
"You can have a voltage measurement of 12V with a circuit that can only provide a few mA of power. Not enough to run your motor." - Partially true. Only when measured open circuit. If the circuit can only supply a few milliamps the voltage at the motor with the switch on will be only a few millivolts.
Al
S/OS #004
Old 04-27-2019, 04:37 PM   #12
Fort Davis , Texas
Al
In my post I was trying to not get too technical with the OP. The below is not directed at ya'll but more to the OP.
Lets say the normal fan circuit with the fan running would show 12V and 5A. Which according to Ohm's Law indicates a circuit with 2.4 Ohms of resistance. In this case the Voltage still reads 12V, but the fan won't run. Assume that the fan requires a minimum of 2 Amps to start.
Back to Ohm's Law:
Assume the circuit is only producing 1A of current, so the fan won't run.
At 1A, with a volt meter reading of 12V on the circuit the resistance has gone up to 12 Ohms. Why?
DC fuses and some DC circuit breakers can blow/trip and still allow a small amount of current through but, because of high resistance, the voltage remains near nominal. This can also be caused by faulty wiring, less than a "short circuit", that adds a high resistance to the circuit. Or as you stated, it could be another device on the circuit that is raising the resistance.
Pat
Old 04-27-2019, 08:21 PM   #13
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Thanks for all of the advise and suggestions.
I measured the amperage draw of the motor. It is only 0.15 milliamps, so it is definitely a weak circuit. Still shows 12 volts.
I have been digging around for where the wire from the fan goes, but not much success as it is in the ceiling behind the interior aluminum. I found where the wire bundle from the ceiling harness comes out of the wall, but have not found where the "Packard" connectors meet and I don't know which wire color I am chasing.
I am charging my bullet video camera so I can try tracking some of this in the ceiling/wall tomorrow.
BTW, the wire color in my circuit drawings do not match the colors in am seeing coming off of the fan. I think they are just trying to see if I will start screaming...
DaveP
Old 04-27-2019, 10:07 PM   #14
Back to Ohm's Law:
Pat
Unless I misunderstand you, which is possible, if the OP is measuring 12V at the motor there cannot be increased resistance on the 12V feed. Resistance in a fuse or the switch will result in a voltage at the motor of (using your resistance numbers) of 2.4/12.4 * 12, or 2.32 volts. The problem must be in the ground line.
The key is to measure the voltage at the motor + and - leads with respect to real ground (battery negative). Low voltage on the + means a problem in the line feeding the + terminal. 12V on the - means a problem on the line feeding the -. If OP is measuring 12V across the motor itself, then the motor is bad or there is a bad connection between the measurement point and the guts of the motor. It is not possible for the motor to have 12V applied and not receive enough current to operate.
The only thing I can think of that might exhibit the described symptoms (assuming OP is measuring 12V on a known good motor and it is not running is that it has a diode in it and he is connecting it backwards, i.e. + wire to - terminal and - wire to + terminal.
Al
S/OS #004
1977 bathroom exhaust fan triciaandjeff Member Introductions 1 05-11-2016 05:05 PM
Replacement Fan Motor for Roof Exhaust Fan SaabLover Furnaces, Heaters, Fireplaces & Air Conditioning 20 01-08-2014 04:00 PM
Bathroom Light/Exhaust Fan Switch shebeen 1974 - 1977 Overlander 2 06-26-2011 12:15 PM
Bathroom Exhaust Fan for 71 Safari rrpranch Roof Vents, Skylights & Fans 12 06-26-2007 06:57 AM
bathroom exhaust fan handle replacement charlie tuna Roof Vents, Skylights & Fans 8 09-08-2006 06:40 PM
