Old 01-05-2019, 07:00 AM   #1
2019 30' Classic
Belleville , Illinois
Help! Electrical issues
2019 Classic 30. Plugged into 30 amp shore power. Neither heat pump is working. Breakers not tripped. And... 15 amp GFCI controlling refrigerator outside receptacle and galley trips. Any ideas short of a long trip to the dealer? Thanks.
Presitla99 is offline   Reply With Quote
Old 01-05-2019, 07:05 AM   #2
Mount Dora , Florida
I would check the shore power pedestal for proper wiring first.
2017 FC 27FB
2017 F250 Lariat Crew Cab 6.2L
Equal-I-Zer 10K/1000
JMynes is offline   Reply With Quote
Old 01-05-2019, 07:20 AM   #3
66Overlander's Avatar
1962 22' Safari
2016 30' Classic
Somewhere , in the USA
Images: 41
Can't help on the Heat Pumps other than to say they won't work if it's too cold outside (near or below freezing).
Regarding the fridge GFCI, they go bad. We had to replace the one in our 2016 Classic last summer. Got the replacement at Lowe's as we were out of warranty. Saw many reports of them going "bad" and tripping for no known reason on various 2016 Airstreams. Seems they got a bad batch that year. Maybe your case is similar. Of course when the GFCI trips, most receptacles in the trailer don't work either, so that also becomes a hassle.
Joe
WBCCI/VAC #6768
66Overlander is offline   Reply With Quote
Old 01-05-2019, 07:31 AM   #4
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Two tools come to mind for simple AC circuit testing, the plug in circuit tester that looks for open neutral, ground reversed polarity etc. And the other is a plug in voltage tester. These plug into outlets and are helpful in non harmful testing, meaning no open probes if you're not familiar with checking outlets.
And a great place to start is at the pedestal as recommended, just plug in with an adapter and test away.
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 01-05-2019, 07:35 AM   #5
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
I bet you the pedestal is wired incorrectly. Reverse polarity or open ground, neutral to ground would be common on a 50amp Plug.
Dept of “OverKill”
GMFL is online now   Reply With Quote
Old 01-05-2019, 07:41 AM   #6
1981 31' Excella II
New Market , Alabama
I agree, check for bad ground or loss of neutral or one of the hots. Each hot should read approx 120V to ground and neutral. You should get 240 ish across the two hots. If you don't know what you are doing then get an electrician.
Perry
Old 01-05-2019, 07:45 AM   #7
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
Our Classic doesn't have one but make sure the 'Bells & Whistle' breaker hasn't tripped...😘
Seriously...hope you find the 'problem', ideally it will turn out to be part of the learning curve. 👍
Sweet Streams
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 01-05-2019, 09:39 AM   #8
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
Outside receptacle may have moisture in it causing GFCI to trip.
I have had to dry mine out using hair dryer on low after bad rain.
Garry
Old 01-05-2019, 02:22 PM   #9
2019 30' Classic
Thank you all. Oberlander nailed it—the heat pump issue—It was too cold outside. Now that it has warmed they both work. We have had significant rain so I’ll see if Garry is correct that it’s an outside
Moisture issue. Regarding the ground fault.
Old 01-05-2019, 03:09 PM   #10
Half a Rivet Short
Carlisle , Pennsylvania
Hi
One correction - if your 50A trailer is plugged into a 30A feed ..... you will measure zero between the two hots on the 50A circuit. You will measure 120V to ground on either one of them. That should be how things show up in this case.
If your 50A trailer is plugged into a 50A feed ... you will indeed get 240 between the two hots and still get 120V to ground on either one of them.
Help! Newbie! Electrical Issues! hiballard1 1977 Excella 500 2 04-20-2014 08:52 PM
Electrical issues! runningbarre Electrical - Systems, Generators, Batteries & Solar 2 06-11-2011 05:11 PM
12v Electrical Issues Clyde-2 Batteries, Univolts, Converters & Inverters 5 10-25-2009 08:12 AM
Help Help Help - Door Lock Issues HowieE Doors & Locks 1 09-08-2009 09:57 AM
2005 CCD electrical issues ablaze Electrical - Systems, Generators, Batteries & Solar 7 10-29-2007 05:57 PM
