Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 04-10-2006, 12:02 PM   #1
Mookie's Avatar
Profile:  1992 21' Sovereign
Oakland , California
Images: 59
Help - Adding Battery
My 1992 Sovereign came from the factory with one battery. I have located a battery compartment in a salvage yard and would like to add a second battery. Do I need to do anything other than wire these batteries in parallel? Will my existing charging system be able to handle the extra battery? I have searched the forums but I haven't found anything on this specific topic.
Thanks in advance for your help.
-Mark
Mookie is offline   Reply With Quote
Old 04-10-2006, 01:25 PM   #2
Zeppelinium's Avatar
Profile:  1970 18' Caravel
1977 23' Safari
1975 31' Sovereign
Palmer Lake , Colorado
No problem. Just wire them in parallel.
Actually, I use an 8-position fuze block for my Caravel--two of them for the batteries. Then I can just pull a fuze (automotive flat type, easy to pull) when I want to disconnect one battery and only use the other (sort of an early warning system, or a usage rate indicator when I'm boondocking--then I have a good estimate of how long the other one will last).
Anyway, just remember you aren't starting a car with these batteries. You can use #8 or #10 wire--makes installation much easier.
One note of caution: If you're going to parallel your batteries, they need to have the same condition, eg, same use, same age. So you really need to buy two new batteries and install them together. If you don't, the less capable battery will quickly "damage" the other battery and you will get much less life out of it than you expect.
Your charger can handle both, if you have a modern charger. If the charging current is high, the charger/converter will self-limit the current. It only takes a few minutes, like one or two, for charging currents to drop down to the 20-30 Amp range. If you're concerned about max current, you can pull one of the fuzes and charge each battery separately if you've run them both down to a low level. If you discharge your batteries separately, you should charge them separately. I don't separate mine very often--too much to remember, too many steps to get right.
Remember, going below 20% charge significantly increases the chance you will damage a battery. I try to stay above 11.5 volts under load, but never below 11 volts.
Current 6-word memoir: Vintage Airstreams: Four are not enough.
www.mindseyephoto.com www.airstreamdoctor.com
Old 04-10-2006, 02:03 PM   #3
Mookie's Avatar
Images: 59
Dazed and Confused
Hey Roger (Led),
Thanks for all the great information. I'll consider adding the fuse panel - where in the wiring scheme did you put it?
On another note, I'm a Led Zepplin fan, too. I love the more recent CD "No Quarter" - awesome.
Thanks again,
-Mark
Old 04-10-2006, 04:32 PM   #4
1977 23' Safari
1975 31' Sovereign
because of where my Univolt had been, the wiring all terminated in a small area, so I put the Intellivolt right there and the fuze block right on top (had to take the cover off and drill two holes). It makes for a compact installation and tight wiring runs.
Roger
Pingbacks are On
Battery Location uwe 1970-76 Tradewind 22 09-04-2003 07:44 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
Extra Battery Placement JaceBeck 1999 Safari 16 10-02-2002 01:03 PM
Auto Battery problems.... kzener40 Airstream Motorhome Forums 10 08-05-2002 06:37 PM
Battery Level Display uwe Electrical - Systems, Generators, Batteries & Solar 4 07-04-2002 07:31 PM
SEO by vBSEO 3.1.0
