Old 02-05-2007, 05:20 PM   #1
k9s2go's Avatar
1985 25' Sovereign
Coast , Oregon
Help! 85 Sovereign electric problem/s
We have a circuit breaker that resets constantly when the rig is powered - either AC or 12 volt. Everything had been fine on our last outing. We noticed it when we returned home and were cleaning up. We found the 12 volt distribution panel behind the front couch and narrowed the problem to circuit 3 (pink).
We've checked the breaker box in the back - its ok. We also noticed that the Control Panel is not lighting up - working. We assume it's powered by that circuit.
How do we remove the front of the Control Panel to access the insides - there doesn't appear to be any screws visible. I've read several posts and there is discussion of fuses - is there a fuse box somewhere for the system???? Haven't found one an our manual isn't clear either.......
Any suggestions would be greatly appreciated! Thanks!
k9s
k9s2go is offline   Reply With Quote
Old 02-05-2007, 06:00 PM   #2
INSANITY CENTRAL
doorgunner's Avatar
1986 32' Excella
2014 Interstate Ext. Coach
Citrus Heights , California
Images: 35
Help has arrived
1984 Airstream Trailer Service Manual page H-16. Control Panel Removal 1- Remove main 50 amp fuses from 12 Volt Distribution Panel. 2- Using care not to damage the surrounding cabinet, gently pry the control panel out. It is hald in place with spring clips that snap into position. 3- Disconnect main harness. 4- Reverse procedures to reinstall. There you go also elsewhere in the manual the pink wire is the one that powers the panel. My 86 has the same stuff the 84 manual calls for. Hope this helps you somewhat. Could be the thermo breaker is faulty. loose wires etc.
www.popasmoke.com
Proud Appellation American
Vine View Heights is now closed.
YETI ( 65 Quart )
IGLOO (Ice Cube, 50 Quart )
doorgunner is offline   Reply With Quote
Old 02-05-2007, 08:36 PM   #3
k9s2go's Avatar
1985 25' Sovereign
Coast , Oregon
Thank you Doorgunner! Question/s.....when you say remove main amp fuses from the panel do you mean disconnect the wire from the panel? Can we just turn off the battery switch? Is there an in-line fuse somewhere in the panel we should look for? We'll check this out tomorrow! Thank you VERY much for the reply!
k9s
'85 Sovereign 25' j54mark 1984 - 1989 Sovereign 13 11-07-2013 11:24 AM
'78 Sovereign Awning Joan D'Andrea Awnings 6 01-03-2006 07:34 AM
voltage for electric jack maznblu Jacks, Stabilizers, Lifting and Leveling 3 04-16-2004 08:32 PM
removing electric jack CHRIS CANNON Our Community 0 09-30-2002 06:51 PM
Help with Ancient Sovereign patti 1955 - 1959 Sovereign 2 06-06-2002 02:23 PM
