Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Electrical - Systems, Generators, Batteries & Solar
Old 07-28-2006, 11:12 AM   #1
garthbf
garthbf's Avatar
Profile:  1975 31' Sovereign
mount vernon , Washington
help, 12v center light not working.
I have a 75 31' land yacht and the center overhead light will not work. I checked the wire for voltage and there is no power to it. It was working and then just stopped. I just got the trailer and was going throught the thing and removing junk, from under the beds and in the overheads, etc. and then it stopped working. all the other overhead lights and all other thing 12v work except that the power outlet by the street side twin bed went out at the same time.
Does anyone know if these two are connected in some way and or where all the lighting black wire come together?
Thanks...
garthbf is offline   Reply With Quote
Old 07-28-2006, 11:57 AM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Check your fuses
Thanks...
Hi, and welcome to the forums. Check your fuses in your univolt. Sounds like yuo blew a fuse, or just maybe moved a wire on the power connector to the 12v outlet.
Old 07-28-2006, 12:54 PM   #3
Jim Clark
Jim Clark's Avatar
Profile:  2005 25' Safari
New Orleans , Louisiana
Thanks...
I assume you other lights are working. If that is the case check all the areas where you moved things around I suspect that you loosened a connection. I use a good flashlight to inspect all the storage compartments and under lockers and sinks. This is a good way to locate where many of the electrical connections are on the trailer. The good thing is that you know it was working and that moving objects caused it to stop so the open connection will be easy to find.
Good Luck
First Weekend Shindig @ Topsail First Weekend in Jan.
Thanks Jim,
http://gallery.mac.com/jimclark6#gallery
Jim Clark is offline   Reply With Quote
Old 08-15-2006, 04:16 AM   #4
RVnDixie
RVnDixie's Avatar
Profile:  1975 28' Argosy 28
Homewood , Alabama
I had the same problem in my '75 Argosy. I found where a wire was broken at a junction area in my upper storage compartment. Hope this helps!
Joseph Tolliver aka "T"
Amy Tolliver
1975 Argosy 28D (work in progress!)
RVnDixie is offline   Reply With Quote
Old 08-15-2006, 06:36 PM   #5
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
Thanks...
You could possibly have a switch that controls that light, that is next to the entrance door opening, on the wall just forward of the door.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
two tiny orange lights on left front side trailer overlander Lights - Interior & Exterior 19 12-12-2003 08:39 AM
Ever toured the Jackson Center plant? KY Girl Our Community 21 11-17-2002 11:04 PM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 09:52 AM
Center folding bed attachment uwe Cabinets, Counter Tops & Furnishings 6 06-30-2002 09:01 PM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
test
