Old 12-22-2006, 09:36 PM   #15
cookeville34's Avatar
Auburntown , Tennessee
Send a message via Yahoo to cookeville34
Lights!
Ok, I used jumper cables from my battery to the hot side of the fuse block and the negative jumper cable to the trailer frame and instant lights. (although the 12volt relay in the Control Console up front did dim them every once in awhile)
I am assuming the main ground must be corroded or something on the other end where I can't see it (it runs behind the shower somewhere not to the fuse block).
1979 Airstream Sovereign International, 31'. VIN# I31T9J0162
1992 Buick Roadmaster Wagon, 5.7L - V8, stock 5000# tow rating, posi, aux trans cooler, rear coil over shocks, 2" rear spring lift kit, flowmaster exhaust.
cookeville34 is offline   Reply With Quote
Old 12-23-2006, 02:38 AM   #16
1992 34' Limited
Falls Church , Virginia
Was this trailer recently from Roswell?? Certainly the Roswell Aliens turned the lights back on for you!
Hurray, you have lights!
Congratulations.
Axel
SilverToy is offline   Reply With Quote
Old 12-23-2006, 04:27 AM   #17
boatdoc's Avatar
1973 Argosy 26
Norristown , Pennsylvania
Arrow Polarity problem
Originally Posted by cookeville34
I attached the battery charger leads to the trailer 12v battery leads. Came up with the same problem.
Hey cookville; You are not paying any attention to azflycaster. In previous reply he has said that you have a bad ground and #3 fuse is what is giving you the needed ground. Check ground wire input at fuse panel, it may be loose or corroded. You may even want to do Resistance check on the ground wire. If the polarity reversal within the battery is suspected, try using another battery to check for it. Thanks, "Boatdoc"
boatdoc is offline   Reply With Quote
Old 12-23-2006, 05:38 AM   #18
Phil Gobie's Avatar
1977 31' Sovereign
Miami , Florida
Check your quick disconnect inside the bat. box. It may have pulled apart when you pulled or replaced the battery. I have done this a couple of times. Good luck Phil
Phil Gobie is offline   Reply With Quote
Old 12-23-2006, 06:36 AM   #19
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Having 12v+ where you should have ground indicates an open in the ground. If needed, run a new ground wire to the frame from the battery. You can use a regular car ground battery cable to do this, they cost less than $10.
If you put the battery back in, and run your jumper cable from the - post of the battrey to the frame of the trailer, and everything works, you have isolated the problem to that one section of ground between the battery and the frame. Just like Richard said above.
Good luck with it.
Old 12-23-2006, 07:50 AM   #20
Alumi-Naught's Avatar
1982 31' Airstream310
Groveland , Massachusetts
12 volt woes
Sounds almost exactly like a problem I just solved on my 310. It was a poor/corroded connection under the fuse holder on the load side of the 50 amp feed out to the univlot. I found if by bypassing the load side connector with a jumper out to the individual branch circuits one at a time. I had a spare 50 fuse in my panel so I am currently using that one. If you would like to talk further pm me and I will give you phone number.
The road goes on forever but the party never ends... (Robert Earl Keen)
Joy, Mark, Eric & Speck
1982 310 Motorhome (Sammie)
AIR #8361
Alumi-Naught is offline   Reply With Quote
Old 12-23-2006, 09:09 AM   #21
2006 30' Classic
Farmington , New Mexico
Images: 14
I agree with Richard--poor grounds will give you some of the crazyest things. While there is a chance of battery polarity reversal , it's highly unlikely.--pieman
Mike Lewis is offline   Reply With Quote
Old 12-23-2006, 04:37 PM   #22
I added a temp new ground to the battery (neg) to the fuse block (neg) and now I have lights.
I did find that the 12v bath fan motor was locked up and red hot, so I disconnected the fan. I'm going to replace the fan with a 12v light to brighten up the bathroom.
Old 12-23-2006, 05:56 PM   #23
1960 24' Tradewind
santa barbara , California
Yes as many have stated ,grounds are such a huge issue that needs to be really checked out and keep them in clean condition,even if they look like they are ok .Over63 is correct also the ground side can become hot due to a poor ground or a ground not connected ,its funny because at first youd think that if you grounded that" hot" ground it would short out ,but it reconnects the circuit and becomes complete again .
Scott
scottanlily is offline   Reply With Quote
Old 12-23-2006, 07:35 PM   #24
While we're talking 12volt, does anyone have experience installing a master 12volt switch on the inside of the trailer?
What about the Command Console where the 12volt relays are?
Old 12-24-2006, 07:20 AM   #25
boatdoc's Avatar
1973 Argosy 26
Arrow Main battery switch.
Hey cookville; Go to a boat store and purchase a SEADOG brand master switch #420600-1. It is rated for 500 amp momentary and 75 amp continuous. This switch will need only 2" depth on the inside of you battery compartment. Cut a 7/8" hole in a battery compartment bulkhead wall, in a place where terminals will be out of the way of the battery. Switch housing has four mounting holes. Use two holes and through bolt the switch to the bulkhead wall using good bead of sealer around the neck of the switch, to seal the fumes from entering the living space. Cut the positive battery lead crimp and solder 3/8" ring terminals onto cut positive battery lead. All you will see on inside is the neck of the switch. Switch comes with a special plastic key to prevent unauthorized use. Good luck, "Boatdoc"
12 volt
12 volt TV? john hd On The Road... 52 07-02-2008 02:16 PM
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 5 03-13-2005 06:20 PM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
Replacing RM100 fridge....troubles? JohnGalt48 Refrigerators 3 04-18-2004 07:13 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
