Old 07-08-2005, 02:16 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Help! 12 Volt Circuit Not Working on 97 Excella
While on my way back from a weekend camping trip near Flagstaff, one of my Airstream tires blew apart causing some damage to black tank release mechanism. The shredded tire also ripped off the outside light attached to the banana wrap. Unfortunately, since this happened the supporting 12v circuit, which supports all bathroom and bedroom lights and the water heater, no longer work.
What could cause this? All of the positive and negative wires supporting this outside light are now capped off (I thought they might be shorting the circuit). Is there something I'm overlooking? The schematic mentions a small reset botton for the breaker but I could not find it. Help!
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
http://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
12 volt
12 volt TV? john hd On The Road... 52 07-02-2008 02:16 PM
Electrical changes 120 volt ac FrankR Electrical - Systems, Generators, Batteries & Solar 5 03-13-2005 06:20 PM
1961 - 12 volt or 6 volt? Marlboro Mafia Electrical - Systems, Generators, Batteries & Solar 4 04-19-2004 09:03 AM
Exterior 120 volt outlet cover thenewkid64 Electrical - Systems, Generators, Batteries & Solar 8 06-16-2002 08:54 AM
New circuit breaker strip FrankR Electrical - Systems, Generators, Batteries & Solar 0 03-27-2002 10:25 PM
