Old 02-26-2013, 06:34 AM   #15
dznf0g's Avatar
Oswego , Illinois
In 40 years of camping (between childhood with parents and as an adult) I've never had anything stolen either.......but it does happen.
-Rich-
Old 02-26-2013, 06:46 AM   #16
2008 25' Classic
Sometimes it's Heaven , USA
I use one made by Progressive also that is portable... I thought it was just another expensive bothersome thing to carry around until our last trip to a GA state park and it discovered that there was "Reverse Polarity" on the post and wouldn't allow that Airstream to power up.... I understand that in addition to possibly getting shocked on the skin of the Airstream that "Reverse Polarity" is not so good for the converter etc... Maybe it was well worth the $300 or so that it cost
COUNTRYSONG is offline   Reply With Quote
Old 02-27-2013, 05:21 AM   #17
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Campers tend to be aware of their own vulnerability, and so practice the "Do unto others as you'd have them do unto you" mentality moreso than the general population. When I was camping at Lake Dardanelle last year, a camper accidentally left behind his portable satellite dish the day after I arrived. Several days later, he came back for it, and found it right where he left it, still set up but not plugged into anything. No idea why it took him so long to realize he'd left it behind, but at least he got it back.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 02-27-2013, 05:42 AM   #18
dznf0g's Avatar
Oswego , Illinois
I've noticed campers seem to generally look out for each other a little more than we do in our "regular" lives as well. Not sure why, but......
-Rich-
Old 02-27-2013, 06:22 AM   #19
Zigidachs's Avatar
2011 30' Classic
Ridgefield , Washington
We once owned a new fiver, and the built-in surge protector was supposed to be transferred to the new unit. The transfer did not occur. We plugged into the utility pole in a very reputable CG and blew up $5000,00 worth of wiring electronics in the unit! ( Yes, the breaker was off when we plugged in)
Now we use an in-line surge protector with a locked hasp to prevent theft.
And before plugging into any CG utility pole, I double check the pole wiring!!!! ....for polarity, etc.
Zigidachs is offline   Reply With Quote
Old 06-02-2013, 08:42 PM   #20
TinCan
graysailor's Avatar
2016 30' Classic
Apache Junction , Arizona
Question, how do you determine whether to get a 30 or 50 amp?
TinCan
graysailor is offline   Reply With Quote
Old 06-02-2013, 09:06 PM   #21
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Easy. Do you have a 30 amp or 50 amp trailer? Does your plug have 3 connectors or 4? 3 is 30 amp, 4 is 50 amp.
BTW I opted for the hard wired EMS. http://www.bestconverter.com/EMS-HW3...lay_p_511.html
and couldn't be happier.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 06-02-2013, 09:07 PM   #22
Zigidachs's Avatar
2011 30' Classic
Your AS should be a 30 amp.....I do not know of any which are 50 amp.....
Old 06-02-2013, 09:28 PM   #23
There are some with 50 amp. Those with 2 AC's for example.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
Old 06-02-2013, 09:33 PM   #24
JFScheck's Avatar
Rockville , Maryland
Images: 33
Two air conditioners and you will have 50amp such as what I had on my 30 Classic - my new 27fb has only one unit (didn't want/need two as in my 30 the second "bedroom unit" only really worked when I closed the door between the two sections) so I'm at 30amp now in the new 27fb.
Lot's of 50 ampers out there - just check your plugs or like I said, if you have to A/C units I would pretty much guarantee you have a 50amp system.
John "JFScheck" Scheck
2015 Roadtrek CS Adventurous XL
2015 Mercedes Sprinter 3500 XL Chassis with Mercedes BlueTec V6 Diesel
**I Love U.S.A.**
JFScheck is offline   Reply With Quote
Old 06-03-2013, 04:14 AM   #25
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Interesting. How/where does this get installed?
SteveSueMac is online now   Reply With Quote
Old 06-03-2013, 04:25 AM   #26
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
This works well for us...mostly at home as we 'dock most of the time.
PFC
but I’m the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 06-03-2013, 07:00 AM   #27
dznf0g's Avatar
Oswego , Illinois
Or this one is pretty common.
Surge Guard 30A Portable with LCD Display | Technology Research Corporation
-Rich-
Old 06-03-2013, 09:31 AM   #28
I installed mine under the L lounge, right next to the converter. I just disconnected the incoming power line from the transfer relay, and connected it to the EMS. Then a short run of 10/3 back to the relay. I put the remote display in the cabinet under the sink since it's not something I need to continuously monitor. I'll take a look at it after connecting to shore power, and check it from time to time to monitor my power consumption when using high draw items.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
New 30 amp plug needed ck21084 Batteries, Univolts, Converters & Inverters 21 09-29-2016 11:42 AM
1968 - Progressive Ind. 30 amp surge protector? Randy Gates 1965 - 1969 Globetrotter 13 10-17-2011 01:35 PM
Room for in-line surge protector in 23' Intl? Hoonanea Electrical - Systems, Generators, Batteries & Solar 0 10-03-2011 11:07 AM
Surge Guard Hookup Aquabud Batteries, Univolts, Converters & Inverters 2 07-28-2011 10:32 AM
Loud Humming Noise from Surge Protector Michigander Land Yacht/Legacy Motorhomes 8 07-23-2011 03:56 AM
