Old 02-04-2016, 11:29 AM   #1
2013 25' Flying Cloud
Middleton , Idaho
Hand crimp tool recommendation
I'm looking for recommendations for a quality hand crimping tool, to crimp up to 10 ga insulated or uninsulated 12V connectors.
This is one that I was looking at, the Anchor 701030 Double Crimp Tool: http://www.amazon.com/gp/product/B00...dp_o_pd_nS_ttl
What are your favorites? Thanks in advance!
Trailbob is offline   Reply With Quote
Old 02-04-2016, 11:43 AM   #2
RamblinManGa's Avatar
2016 28' Pendleton
Scottsdale , Arizona
Hi from AZ. . . I've always used Klein tools , needle nose, side cutters etc. My crimper is a 1010 long nose.......regards, Craig
WBCCI 2851,4CU
RamblinManGa is offline   Reply With Quote
Old 02-04-2016, 11:54 AM   #3
2010 28' International
Annapolis , Maryland
The Ancor ratcheting crimper you are looking at is excellent. It will produce very consistent crimps. There are several manufacturers in the electrical industry that make this type of crimper and they are very similar in quality. The only difference is usually in the shape of the grips. You will be pleased with the Ancor crimper.
wander-west is offline   Reply With Quote
Old 02-04-2016, 12:00 PM   #4
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I have been using a Klein crimper just like this one for over 30 years. I think I paid less than $5 for it back then.
http://www.amazon.com/Klein-Tools-10...l+hand+crimper
MICHAEL
Old 02-05-2016, 10:46 AM   #5
1976 31' Sovereign
Oswego , Illinois
Home depot, menards, lowes, other big box stores have same kind of tool for lot less money. I use old crimper that is heavy like pliers. Over 50 yrs. old have never seen another like it. It has cutter like side cut pliers at nose then crimper.
Old 02-05-2016, 11:02 AM   #6
SuzyHomemakr's Avatar
1972 29' Ambassador
Boynton Beach , Florida
I've been using a GB Crimper: http://goo.gl/YuNYT3
The crimping part of the cheapo wire strippers just didn't do it for me, especially when trying to crimp on to solid wire. In that case, I use Anchor marine terminals (like from West Marine) instead of the ones from the auto parts store. Adding a bit of solder works even better!
SuzyHomemakr is offline   Reply With Quote
Old 02-05-2016, 11:27 AM   #7
2019 27' Globetrotter
Salem , Oregon
If you have a ham radio supply store in your area this would be a good place to find exactly what you need.
NoResults is offline   Reply With Quote
Old 02-05-2016, 02:41 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
The very best crimpers are usually the ones sold by the makers of the crimp fittings. They are made specifically for those connectors and provide the best crimps. Anchor crimp connectors with Anchor crimp connectors.
BTW, the ABYC does not endorse soldering with crimp connectors as the solder will stiffen the wire outside the connector which creates a potential break hazard. Solder will also add to corrosion potential from dissimilar metals.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Old 02-05-2016, 06:56 PM   #9
2007 22' International CCD
Lew is absolutely correct.
Soldering is completely unnecessary with a properly made crimp. Use a good ratchet tool and do a pull test.
Old 02-06-2016, 12:43 PM   #10
Middleton , Idaho
Thanks all for your input!
Old 03-04-2016, 10:52 AM   #11
Middleton , Idaho
Follow-up
I did a lot of research on hand crimp tools, and found some really good information on boating forums. I posted a couple of links below if anyone wants more info; this is just a small sample of what I found.
I ended up buying a crimping kit from Proskit, that was recommended on a few sites. With this kit, you buy a frame and then buy the dies for the type of terminals you are crimping. So far, for the price, I have been very pleased with how it works. I listed the part numbers of what I bought, below. I bought mine directly from Proskit.com, but I have since seen some items on Amazon.
A side note, after I got the new crimping tool I wanted to upgrade some wiring in a 14' boat. I had previously wired it up for a trolling motor, and other electronics, approx. 10 years ago. I used Anchor brand connectors, but used the inexpensive crimpers I had at the time. When I started to disassemble the old wiring, I found several crimps had failed and would pull apart with very little force. I'm hoping the new crimps will hold up better...
Proskit:
Pro Crimper Frame: Model: CP-371
Single crimp die for insulated terminals (heat shrink): 9PK-3003D27
Crimp die for uninsulated terminals: 9CP-236DN
Double crimp die for insulated terminals: 9CP-236DH
Test article/video on various crimping tools:
http://forums.sailboatowners.com/ind...esults.125926/
-Bob
Old 03-04-2016, 11:21 AM   #12
Zil
Curtis Wright
Eyren Haven , South Jersey
Maine Sail is the expert that shares his knowledge. Try some of his other articles here; http://www.marinehowto.com/
Zil is offline   Reply With Quote
Old 03-04-2016, 03:40 PM   #13
Wise Elder
Jammer's Avatar
2010 30' Classic
That one, and any of the ratchet ones, should be fine. I have one that is quite similar but a different brand.
Old 03-04-2016, 06:06 PM   #14
lewster's Avatar
This is my go-to crimper for most smaller applications: http://www.waytekwire.com/item/560/C...TERCHANGEABLE/
I have 2 of these frames and 8 interchangeable heads for a variety of crimping applications, from 22 AWG to 10 AWG, RG-45 ends, Weather Pack waterproof plug sets, co-ax cable and others.
Great tool!
Old 03-05-2016, 07:24 PM   #15
Middleton , Idaho
Thanks for that link. Interesting articles.
PEX crimp vs. press on Sharkbite experiences idroba Fresh Water Systems 17 08-31-2011 09:15 AM
Hand riveter tool Sunset Coast Ribs, Skins & Rivets 5 03-30-2008 05:02 PM
5V Crimp tinhutjohn Winterizing, Storage, Carports & Covers 8 01-11-2008 11:58 PM
PEX - Crimp or Flair-IT Dano57 Fresh Water Systems 16 01-27-2007 11:55 AM
water supply crimp ring Lido&Linda Airstream Motorhome Forums 6 10-23-2003 06:58 PM
