Old 01-12-2012, 12:05 PM   #1
1972 31' Sovereign
1973 31' Sovereign
Half of the outlets have no power
This is weird.
While testing the outlets we found that half (the front) has 110V on every outlet but from the middle to the back nothing.
Replaced every braker and we still have:
Power to the Univolt (unit removed because is dead)
Power to the front
Power to the AC.
No power on the rest of the trailer.
How should we troubleshoot this?
Still One Nation Under GOD
VeggieBullet is offline   Reply With Quote
Old 01-12-2012, 12:25 PM   #2
Skater's Avatar
1995 30' Excella
Bowie , Maryland
Send a message via ICQ to Skater Send a message via AIM to Skater Send a message via Yahoo to Skater
Start by pulling the outlets out (with the power OFF) and check the connections.
1995 Airstream Classic 30' Excella 1000
B190 Owners: The site B190 Enthusiasts is dedicated to the 1989-1999 Airstream B190.
Skater is offline   Reply With Quote
Old 01-12-2012, 12:29 PM   #3
1972 31' Sovereign
1973 31' Sovereign
still nothing
Hi Skater.
Thanks for the fast response.
Done that and still nothing going to the outlets.
Old 01-12-2012, 01:36 PM   #4
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
I would check the outlets again. The outlets are daisy chained. I found that this was a problem on my 73 Safari
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2006 F250 superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 01-12-2012, 01:54 PM   #5
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would look for a wire that has been disconnected. It may not even be in the load center. Check to see how many Romex cables come into the load center then make sure that all three wires in each cable are connected. Also look outside the load center for a Romex cable hanging lose.
Old 01-12-2012, 02:15 PM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
First check the breaker, they do go bad. Then if it is ok clip a long jumper to both the black wire (in the breaker) and then white wire ( attached to the ground buss) and use your volt meter or even a self powered test light to check for continuity from the wires in the first outlet. Check both black and then the white. If you have continuity at the first box work your way down and check the next one. You should get a beep or a light. I am assuming you know which breaker controls the dead outlets. Make sure there is not a GFI outlet in that circuit, if so they go bad. If the outage is on the curb side be sure and check the outside outlet. Many times they will corrode due to years of water getting in and if it is first outlet on the run it could be the problem. A bad outside outlet was in my 68 was the cause when I had a similar 120v issue.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
TAC-MS-3
KF5IMA
Old 01-13-2012, 07:05 AM   #7
1972 31' Sovereign
1973 31' Sovereign
WOW... I feel honored but this thread! all replies from Rivet Masters!!!
Love this forum and the members just always ready to share their knowledge.
arodriguez60. I would check the outlets again. The outlets are daisy chained. I found that this was a problem on my '73 Safari
There is no power going to the outlets at all.
TG Twinkie
Double checked the load center and everything seems fine. Even changed the order of the brakers and everything seems functional. But no power at the end of the wires to the outlets.
68 TWIND
Replaced all the breakers just in case. Unfortunately I don't know which breaker controls which outlets and it will be nice to know in case u have it handy.
Only one that I was able to identify was the one for the univolt.
Did not find any outlets with GFI neither on the '72 nor the '73 so is that an owner's upgrade decission?
Old 01-13-2012, 08:04 AM   #8
1972 31' Sovereign
1973 31' Sovereign
Load center pic
Only pic that i have while chancing the brakers.
Hope it helps on anything.
Old 01-13-2012, 06:57 PM   #9
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 59
I don't know if this really applies to your age rig, but in ours, all the outlets on the sink and vanity side of the rig (that means about half the outlets) together with the outside outlet are on the same GFI system. However, you can't reset the GFI at the individual outlets. We have go to the fuse/breaker panel, turn the breaker off, then back on, and there's a GFI reset button there, too. Just thought I'd mention it.
TB & Greg - Sadie Cocker & Abbey Schnauzer
AirForums #21900 . Membership Chair, 4C
Unit #3954
Inside AZBambi: AZBambi Décors
Old 01-14-2012, 05:47 AM   #10
68 TWind's Avatar
1968 24' Tradewind
Veggie,
First check the outside box have not done that yet, many folks have found the fix to a bad circuit in the outside box. Make sure it is not wet or corroded. There should be a wiring diagram at the AS web site in the owners manual for that year, you can check. They have an archive section. That said, using a jumper wire very quick and will tell you what you actually have rather than what you are supposed to have as far as how it is wired. Get a piece of light gauge (18) that is long enough to reach from the breaker box to every outlet in the trailer (say 25 ft or so) and attach an alligator clips on both ends. Inside the breaker box attach one clip to a lead that screws into the breaker (a hot wire). Take the other end into the trailer and clip it to one lead of your test light or volt meter (set it to the tone setting so it will beep when the probes touch). Now all you have to do is insert the other probe into the sockets one at a time till you hear a beep or see a light. Then you will know which wire in the breaker box goes to that outlet. Then so on down the line. To it for the hot wires and then go back and do it for the white (neutral wires) to make sure both are making it to the box. Take a piece of paper and make a diagram, also number the wires in the box so you won't get them mixed up. When finished you will have a complete picture of which circuit controls which outlet. There will be one circuit that you won't find a beep for and that will the the line to the AC. All the others should be easy to map out. If you find an outlet that does not beep when attached to any of the wires in the breaker box you will have found the probable cause of the problem.
Hope this helps.
This is exactly how I figured out the wiring in my Trade Wind.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
TAC-MS-3
KF5IMA
Old 01-14-2012, 07:10 AM   #11
1972 31' Sovereign
1973 31' Sovereign
TBRich
Not really sure if there is a GFCI in the trailer since i couldn't found one anywhere including at the main braker box.
68 TWIND
The outside box is fine.
Can I just bypass the outside outlets so see if that was the issue or they need to replaced?
Will check on the AS's site for the manual. didn't even think about that
Will return to the project on monday
thanks again guys
Old 01-14-2012, 07:38 AM   #12
Melody Ranch's Avatar
1956 22' Flying Cloud
1998 30' Limited
1947 22' Liner
Valley View , Texas
Images: 47
In the first description you mention that the Univolt was removed because it was dead. Did all the outlets work before the Univolt was removed? Did you replace theUnivolt with a converter? Did you replace the Univolt with a battery charger? Anyone of those items could be a beginning for your search. I also like the idea of a popped GFCI. Look again there.
Melody Ranch is online now   Reply With Quote
Old 01-14-2012, 08:08 AM   #13
1972 31' Sovereign
1973 31' Sovereign
Hi Melody Ranch
the test of the outlets was performed before the test and removed of the Univolt was removed.
The univolt has a separate braker on this unit so I was assuming that this will not affect the issue.
I will love for this to be a GFCI somewhere but I can't find one anywhere in that trailer. Nothing on any outlet or at the main box nor close to it.
Any suggestions about where it can be?
Old 01-14-2012, 09:59 AM   #14
jkcru's Avatar
2010 28' Flying Cloud
Escondido , California
Your Univolt probaly pluged into an outlet under the sink or such. Reconnect the Univolt wire to the ckt bkr and check.
jkcru is offline   Reply With Quote
Power Loss & Pets Inside? Frank&Mike The Pet Forum 51 05-10-2012 08:34 AM
No power to 12v outlets on Dash dgmelp Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 3 12-12-2011 08:50 PM
Interior power out in half of argosy. Cognito Electrical - Systems, Generators, Batteries & Solar 2 09-25-2011 11:49 AM
Newbie has power questions Czechitout Electrical - Systems, Generators, Batteries & Solar 2 08-07-2011 04:20 PM
120 volt outlets from battery power? etobolski Electrical - Systems, Generators, Batteries & Solar 4 04-05-2011 02:15 PM
